All process in 5 sec. Twrp writes that the installation was ok, but after rebooting - only stock! What are your thoughts on this matter?
[ROM] Beelink GT1 / Alfawise S92 TVStock Nexus ROM (Android TV 6.0)
Guest
Guest
Originally posted by Wyle View PostCan this ROM work on H96 Pro PLUS boxes?Last edited by Guest; 30 March 2017, 09:49.
Guest
Originally posted by Wyle View PostHmm... USB Burning tool? - I don't have a cable to patch my PC to my box... Box uses USB 2.0 port TYPE 2(?)... same as PC. Tried using a USB mem stick but it wasn't recognized.
SD Card? Sorry if I wasn't clear.. that was the second method I tried.
I'm trying Supercelerons' SCV3-ATV ROM again - Still see long reboot times with that ROM..... but at least I got 4K Youtube working again and have fixed Darkeness issue with build.prop fix.
Hate the Launcher, though... can't add anything to it..but family loves "live channels" feature.
I will try to re-burn NEXUS ROM on my box this weekend..sooner if I can - maybe I can scavenge two old USB cables to make a BURN cable! Thanks Magendanz for replying!
You can add anything to launcher just have to read up on how Mine has long rows with everything i have. Movieshd/ Ftmc/showbox/dropbox/megahd/vevo/pluto/chrome/trenium/Modbro/Cartoon hd/Netflicks/esfile/Ya not naming the other 60Many devices now mk902ii/Shield/Mk68 /Ugoos/neox5/minix5 (yes they still work lol) mk80 no it doesnt work lol.
Guest
Originally posted by Wyle View PostSD Card? Sorry if I wasn't clear.. that was the second method I tried]
(And by all means go with Superceleron's ROM if that's what you prefer. It's not like any of us get paid for this, and so we're not competing for customers. We share resources, and so it really comes down to personal philosophy of the ROM developer. I prefer my custom ROMs "clean", with the fewest possible 3rd-party apps, hacks, or gratuitous customizations.)
Magendanz
All is ok. Your ROM is very nice. I flash it with USB burn tool only through USB 2.0. Respect. It would be nice to change the color of the selected items (yellow or blue for example in HDMI-CEC item) in the settings menu, because i almost do not see them on my tv. Can have a solution?
And i have another question - Can you tell me how to install Android TV Remote Control Service on stock rom Beelink GT1? I found com.google.android.tv.remote.service_2.0.0.3777408 .apk but I can't install itI express great gratitude for your efforts. Thank you in advance.
Originally posted by Magendanz View PostIt sounded like you installed the OTA update (.zip file) from the SD card with TWRP. Did you trying creating an SD bootcard using the burn package (.img file) and BootcardMaker app?
We do this for fun, and we do it how we like it for hour personal use and yes from time to time we do listen to ppl requests and we do share resources with each other that is how a team works
And never forget we are hobbyist and do this for fun!!
Sorry Magendaz for hijack your topic !
I am trying again today. First SD card (BootCard) method and if that fails, I'm trying USB stick with ZIP file (TWRP?) method afterwards.
I'm curious about trying out both ROMS'... I really appreciate all the work you ROM DEVELOPERS are doing - I'm not playing favorites, I just want to sample every one's work!
Ok, I decided to try TWRP+ZIP method, First.
Here Is how I tried installing this TVSTOCK ROM to my H96 Pro Plus 3G+32G (DDR3) device:
(Tell me where I went wrong, if you may)
1- powered down device and then turn it on while holding IN Pin (with a toothpick)
2- Loaded into recovery, which I loaded onto an SD Card and inserted into device)
4- I WIPED all the CACHE's...
5 Went to INSTALL: Selected OTG-USB as a source, and Selected ZIP (update_GT1_110M0_TVStock-20170319.zip)...and INSTALLED.
6- Fail Error: 7
I attached a photo of my TV screen so you can see all the interaction and error. Can you see where I may have gone wrong? I'm wondering if it's not my technique!
Guest
Originally posted by Wyle View PostHere Is how I tried installing this TVSTOCK ROM to my H96 Pro Plus 3G+32G (DDR3) device...
To even try to run this on any device other than a Beelink GT1 or Alfawise S92, you need to flash the burn package (.img file). If you don't have a male-to-male Type A USB cable, then USB Burning Tool isn't an option and you'll need to follow the instructions for BootcardMaker to install with an SD card. This is not the same as flashing a .zip file in recovery.
There are currently 2129 users online. 0 members and 2129 guests.
