[ROM] Beelink GT1 / Alfawise S92 TVStock Nexus ROM (Android TV 6.0)
Guest
That's very strange. What wireless chipset do you have? (Does your serial number begin with an A912?)
Originally posted by Magendanz View PostThat's very strange. What wireless chipset do you have? (Does your serial number begin with an A912?)
seems better since i went into settings an forgot password then reentered the password from complete power off an some times from sleep or if just for some reason it disconects basically never though it seems to not auto reconnect to known network so small bug there some where
Guest
The Sunvell T95K uses the same Amlogic S912, so I'd think so. We just need to determine what wireless chipset it's using. I'm downloading the latest firmware right now to take a look, but I'm guessing it's either the Qualcomm QCA9377 or AMPAK AP6255. If it's the latter, you'll need to install the updater in TWRP after the flash to restore wireless functionality.Last edited by Guest; 27 February 2017, 03:07.
Guest
Just posted a new release that fixes the issue with the Android TV Play Store (PhoneskyKamikazeCanvas) incorrectly upgrading apps to versions not designed for Android TV.
Hi thank you for taking time to answer an improve this great rom.
I managed to replace the remote.conf file through terminal, that's OK
Installing Wifi update right now...
[Edit] : Even with Ampak 6255 update no Wifi or BT working so i guess T95K Pro has really different radio hardware.
Last question : to have your new release, do i have to reflash the box? Or is there a way to just update the existing?
[Edit] : just reflashed latest version for the moment.
Many thanksLast edited by Cinquieme; 27 February 2017, 16:46.
Guest
Anyone have a 4K display to test with YouTube for Android TV (YouTubeLeanback)? The 1080p looks awesome, and I can play 4K content from Kodi, but YouTube doesn't want to serve me 4K streams if I can't display that resolution.
Originally posted by Magendanz View PostCinquieme , I was looking through the Sunvell T95K Pro ROM and they've provided drivers and firmware for MANY different wireless chipsets (62X2, 4354, 4356, 6212, 6255, 6335, 43458 & AP6330). So, is there any chance you can take a peek at the board to see what you've got?
Well i don't know if there's any software app to get the refs (tried Aida64 but since i already flashed the rom it gave no useful data)
Well i took this picture of the bare naked T95:-) I must admit it's not obvious to me to recognise the wireless chipset.
Regards,You may only view thumbnails in this gallery. This gallery has 1 photos.1 Photo
[Edit] Hosted picture to have a real size view :-)Last edited by Cinquieme; 28 February 2017, 10:28.
There are currently 4026 users online. 0 members and 4026 guests.
