[ROM] Beelink GT1 / Alfawise S92 TVStock Nexus ROM (Android TV 6.0)
Guest
Originally posted by meriox View Post
Hello again, Magendanz. It's been a while since I last posted here but I have some updates to report.
You mentioned that it's possible to change the boot animation by copying a bootanimation.zip file to the root/system/media folder but this didn't work for me at first. The reason why is because the file also needs the correct (644) permissions in order to take effect.
I tried out the Mouse Toggle for Android TV app on the Beelink GT1 since the app supports the Xiaomi Mi Box which uses an Amlogic SoC. Unfortunately, the volume down then up sequence only adjusts the volume on this device rather than triggering the mouse mode.
Another Android TV app that I use is TV Boot which is available at https://play.google.com/store/apps/d...elgauci.tvboot. I would suggest this free app for inclusion in future updates of your ROM but its shutdown option is disabled and the reboot to bootloader option only performs a regular reboot on the Beelink GT1. The bootloader option works fine on my Google Nexus Player, though. Does the Beelink GT1 have an accessible bootloader menu?
The HDMI CEC support in your custom ROM is something that I think is convenient. When I use a T3 air mouse remote, however, its power button puts the Beelink GT1 in to an instant sleep mode which doesn't cause the TV to turn off. Do you have an idea as to why this happens? There's a discussion thread about the T3 air mouse remote at http://forum.kodi.tv/showthread.php?tid=278842.
I've gone ahead and ordered a Beelink GT1 Ultimate but it probably won't arrive for at least a couple of weeks. Do you plan to release any custom ROMs for that model or are your current ones okay to flash on the device? I remember you said that your initial analysis of the Beelink GT1 Ultimate firmware showed no major differences compared to that of the normal Beelink GT1. However, I noticed that superceleron has released custom ROMs for the newer model so I wonder if you plan to do the same any time soon.Last edited by GNex5; 02 April 2017, 06:49.
Guest
Originally posted by GNex5 View PostI've gone ahead and ordered a Beelink GT1 Ultimate but it probably won't arrive for at least a couple of weeks. Do you plan to release any custom ROMs for that model or are your current ones okay to flash on the device?.
Guest
That's disappointing to find out, Magendanz, but I understand that you're not obligated to do so. If Beelink or GearBest or a fan of yours from this forum is able to donate a box to you, would that change your mind? Alternatively, if people here are willing to make donations in order for you to purchase a GT1 Ultimate, is that okay?
Guest
Originally posted by GNex5 View PostThat's disappointing to find out, Magendanz, but I understand that you're not obligated to do so. If Beelink or GearBest or a fan of yours from this forum is able to donate a box to you, would that change your mind? Alternatively, if people here are willing to make donations in order for you to purchase a GT1 Ultimate, is that okay?Last edited by Guest; 03 April 2017, 19:59.
Thanks for being open to the idea. I'll see what I can arrange. I also have another question for you. If someone flashes your full burn package .img file and you've released multiple updates since then, is it necessary to flash all of the zip file updates (one after another) in TWRP or is it okay to flash just the latest update?
Guest
Originally posted by GNex5 View PostIf someone flashes your full burn package .img file and you've released multiple updates since then, is it necessary to flash all of the zip file updates (one after another) in TWRP or is it okay to flash just the latest update?
Originally posted by GNex5 View PostExcellent! Thanks for the confirmation. I've contacted GearBest about the idea of sending you a Beelink GT1 Ultimate (as they did for superceleron) so I hope that happens in the near future. Keep up the great work.
my GT1 with Magendanz nano rom...MINIX U1, MINI MXIII, MINI MXIII II, GT1, SEA I
Originally posted by KAA View Post
nice work mate...
There are currently 1762 users online. 1 members and 1761 guests.
