[ROM] Beelink GT1 / Alfawise S92 TVStock Nexus ROM (Android TV 6.0)
Guest
Yes, that was what I was going to suggest as well. I believe it's a first-run issue with detecting the remote. When you relaunch, you'll get the big checkmark when you press the Select button, then all should be fine.
Originally posted by tillaz87 View PostGuest
if you add this to the build.prop it enables 2k/4k on YouTube, this was the only thing i was missing, looks to be all working fine
Code:sys.display-size=3840x2160
I suggest we investigate before adding onto next update. Btw this rom made my s92 alfawise starting S/N H912 buttery smooth.
Originally posted by asadmari View Post
I did this, the box freezes on 4k contents and I have to hard reset by unplugging the wire, not sure if I have faulty box , also after I hard reset, it has to optimize the apps all over again. I do have the darkness fix enabled if its makes any difference
Originally posted by tillaz87 View Postworks fine for me on beelink GT1, I dont use the darkness fix not sure what that is
after factory rest does it do the same thing? i added it the build.prop then repackaged ad flashed with burn tool as i was doing my own thing
i did not do factory reset neither did flashed it. i just added to the build prop
Originally posted by JesuZConte View Post
Youtube for instance... but I think it's related to Chromecast ? Maybe that's why it doesn't work u.u
there was a work around to get it working not sure if it was killed off though. have a look here
https://forum.xda-developers.com/and...droid-t2900726
Guest
Originally posted by kokah View Postcan i installl this rom on k2 pro s905,looks nice
Originally posted by Magendanz View PostSorry, this is designed for the q201 reference board, which uses the s912 chipset. You could try this similar custom ROM for the s905, though.
Hi Magendanz,
Everything works great on my Beelink GT1 except one minor problem. Some apps, e.g., foodnetwork, hgtv and travelchannel, seem not working correctly. I can use Down Arrow key to show/hide caption and OK button to pause the vide with Superceleron's SCV9A rom. For some reasons, they are not working with your latest rom. Do you know how to fix the problem?
Guest
Originally posted by Jack Kuo View PostSome apps, e.g., foodnetwork, hgtv and travelchannel, seem not working correctly. I can use Down Arrow key to show/hide caption and OK button to pause the vide with Superceleron's SCV9A rom. For some reasons, they are not working with your latest rom. Do you know how to fix the problem?
There are currently 4053 users online. 1 members and 4052 guests.
