[ROM] Beelink GT1 / Alfawise S92 TVStock Nexus ROM (Android TV 6.0)
Guest
Originally posted by fred73140 View Postthis rom is really great, but amazon prime video doesn't work any ideas?
Been finishing up comparing are system to mi box, All of these below are left behind from apk / not needed or not part of atv
all in system/lib
VideoPlayer.apk
libsubjni.so
PPPoE.apk (Point-to-Point Protocol over Ethernet)
libpppoejni.so
libpppoe.so
RemoteIME.apk
libjni_remoteime.so
libnfc_ndef.so
(The NFC service present in the android device relies on 3 main driver components : libnfc.so, libnfc_jni.so and libnfc_ndef.so)
These are from something that was actually never in are rom - (com.youku.tv.c) Youku TV (com.hpplay.happyplay.mainServer) (com.hpplay.player.Photo)
libhpplayvideo19.so
libhpplayvideo.so
libhpplaysmdns.so
libhpplaymdns.so
libhpplayaudio.so
libhisivideo19.so
libhisivideo_3798m.so
libhisivideo.so
vendor\lib
libfrsdk.so = part of face lock not part of atv
Hello,
First, thanks for files and tutorial.
Now, my problem is i'm missing something on the part "install the AP6255 UPDATE in TWRP after you flash the ROM to restore WiFi functionality."
I guess i have to install the file from adb or from sdcard in recovery mode, but when i start the box using the pin, i get stuck on nexus logo.
Anyone can help a beginner ?
Other question, is there a place to download official beelink android in case i would like to install it back ?
Thanks in advance.
Thanks in advance.
the link you would need http://www.bee-link.com/Beelink-2357-1-1.html
Originally posted by Magendanz View PostI'm working on brining ATV 7 to the Amlogic q20x reference boards (M8S Pro, KM8 P) now, but am blocked on TWRP. Have had some success with the Z28 (Rockchip RK3328), but resolution is only 720p and am hitting some Open GApps compatibility issues. At this point, the Beelink GT1 only has an early beta of Nougat which was pretty rough around the edges, and so I've been waiting for the official release.Thank you for these roms
There are currently 1187 users online. 1 members and 1186 guests.
