[ROM] Beelink GT1 / Alfawise S92 TVStock Nexus ROM (Android TV 6.0)
Originally posted by tillaz87 View Post
What apk's ? Bluetooth devices should pair like normal without additional apk. plus I've not removed anything that's in the mibox stock firmware as that's what i'm comparing against
so it would be strange for the remote to need something that's not in the firmware it ships with. I have paired xbox controllers, amazon tv remote, headphones without issue
Like i said thought i can add settings back, if not that's fine. what i post is for anyone here that's interested. and most is backed up with proof. you dont need to include it.
but everything i removed really has no use.. other than settings.apk which i can see might want to be kept.
Guest
Originally posted by majussiani View PostWorks on GT1 Ultimate G912 | q201_9377 ?
Since I bricked my GT1 Ultimate box reverting to the OEM GT1_311M0 firmware right after posting my first custom ROM for that hardware, I haven't been able to maintain that build. It still has an intermittent hanging issue with the GT1_312M0 kernel and has received none of the regular updates that I've released for the standard GT1 here. I'd recommend it only as a foundation for those trying to build their own custom ROMs for that hardware.
Originally posted by sweetnonso View Post
tillaz87 I think Magendanz was being too polite. It probably will serve you and anyone that may want to sample your work best if you go do your own rom, start your own thread etc, instead of piggybacking on someone's else. That way, you could customize it all you like to suit you...Last edited by tillaz87; 21 June 2017, 08:02.
Originally posted by Magendanz View PostNo, there's a separate thread for the GT1 Ultimate...but there's a major caveat.
Would you recommend some ROM with the AndroidTV interface?
Guest
Originally posted by majussiani View PostWould you recommend some ROM with the AndroidTV interface?
Proper Android TV Bluetooth Function
Flash in recovery Link
How To Add 4k Youtube
Edit your build.prop to match the = values
Code:ro.product.model=MIBOX3 ro.product.brand=Xiaomi ro.product.name=once ro.product.device=once ro.product.board=once ro.product.manufacturer=Xiaomi ro.build.product=once
Code:sys.display-size=3840x2160
This might help you with the action bar problems
https://github.com/hushnymous/androi...1295c81876a38f
edit:
tried this and it made no difference.Last edited by tillaz87; 22 June 2017, 03:43.
Last thing i was missing from proper atv was the package installer view, I couldn't find how stock atv overrides the default holo.light theme so i just changed it manually.
here is how for anyone that wants to know.
GooglePackageInstaller\res\values\styles.xml
Change
Code:<style name="Theme.DialogWhenLarge" parent="[COLOR=#FF0000]@android:style/Theme.DeviceDefault.Light.DialogWhenLarge.NoActionBar[/COLOR]" />
Code:<style name="Theme.DialogWhenLarge" parent="[COLOR=#008000]@android:style/Theme.Material.Dialog.NoActionBar[/COLOR]" />
Probably last post from me on here.
Originally posted by fedmond31 View Postabout Amazon prime vidéo App, it does run with OEM firmware and Superceleron V8C (not ATV)
I have extracted my app from same box , on Android TV app launches Ok but stops whenever you start watching a movie. App must be blocked by Android TV OS or device type ?
From the burn image I removed
system\xbin\supolicy
system\xbin\su
system\xbin\daemonsu
system\bin\.ext
Then flashed, and My5 now works. I then rooted via twrp with chanfires system-less root and my5 still works after. i flashed the latest .zip (V2.82)
http://www.supersu.com/download or https://forum.xda-developers.com/app...lease-t3452703
@fedmond31 Can you send me the prime video app that was working on other roms or link me to it ? I just got prime so wanting to see if can get it working.
Hi Mangendanz, where is the AP6255 UPDATE fort the 313 version please. I can't find it anywhere.
Thank you
Ok I have checked... Selinux is still disabled on this build... If you can Mangendanz it could be great to have the selinux support + Magisk so that we can pass safetynet... If you want not to do this can you please, al least, send me the sources of your Kernel so that I can ask a friend of mine to enable it for us? Thanks
Guest
Originally posted by Aldo_97 View PostOk I have checked... Selinux is still disabled on this build... If you can Mangendanz it could be great to have the selinux support + Magisk so that we can pass safetynet... If you want not to do this can you please, al least, send me the sources of your Kernel so that I can ask a friend of mine to enable it for us? Thanks
There are currently 4052 users online. 1 members and 4051 guests.
