[ROM] Beelink GT1 / Alfawise S92 TVStock Nexus ROM (Android TV 6.0)
Originally posted by fred73140 View Postthis rom is really great, but amazon prime video doesn't work any ideas?
Unfortunately cannot get Amazon Prime to work. I checked many forums, installed all the amazon apps just incase it had interdependencies, including Underground, Music and Kindle (saw on another site) but no good. I get the pop up 'Unfortunately, Amazon Video has stopped working' but the video is playing behind it. If I close the pop up it goes back to the Amazon Prime Video home screen. Any way to make this work please.
Your help is much appreciated and thank you again
Guest, any reason why I can't enable any apps as device administrators or allow a VPN to automatically start at boot?
i have a NetXeon Mini M8S Pro (s912) do you thinks it will be good to flash your rom over it (right now i have the latest firmware 703N0 (7.1.2).
i thinks it's a clone of GT1 and alfawise.
thanks
It's mainly a benefit for custom ROM developers like me, since it's one ROM that supports multiple DRAM configurations, the most popular wireless chipsets, and the most common IR remotes. It's easier for us to roll out support for many devices with one ROM and users are less likely to install the wrong firmware for their device.
ok thanks
just another question
i see you make a rom with android tv 7.1.2.
wich is the best, this one with android 6.0 or the new one with android 7.1.2.
I'm new to android TV system and for now just use my box for émulation, kodi, molotov .
thanksLast edited by Killerdog; 20 September 2017, 07:50.
thanks
Now the best for emulation i think is the normal, since atv one is more of a media player... but it works the same on both!
Sorry, my bad, i forget to add TV to Android TV 7.1.2.
some app is a way better in android tv system (for use with a remote) i agree with you.
i see Magendanz have done 2 rom with android tv, one with marshmallow and the other with nougat.
my question is wich is the best to use (buggless, functionnality etc...)
Originally posted by Killerdog View PostSorry, my bad, i forget to add TV to Android TV 7.1.2.
without testing it self you never will know .
nice Day / gefattern
Thankyou thankyou for your work i'm much reading and i decide to try.....first i try sdcardmaker but i'm wrong something.....(device not boot at all) then i build USB cable and try Burning tool with success!! Your Rom are wonderfull.
I stay on Android 6 beacuse i see that 113M0 at the moment are fw that rum smooth on GT1
Another time Thankyou i'm reading all you update also on 7.1!!!
There are currently 1406 users online. 0 members and 1406 guests.
