[ROM] Beelink GT1 / Alfawise S92 TVStock Nexus ROM (Android TV 6.0)
Guest
Originally posted by pszab View Post
does anyone have problems writing to a USB stick on this ROM? for example I cannot make a backup of Titan skin onto the USB like I used to do on stock ROM. also, an old Titan skin backup I used frequently on stock rom to restore settings is no longer being read when using this rom. any info would be greatly appreciated. thanks for a great rom!
@Magendanz , thanks for the awesome firmware. I am a newbie in this. Can you pls tell me how to enable DMR support in this? Also any fix/workaround to get rid of dark screen problem?
One more thing, in the notes you mentioned that android tv remote is working but I am unable to connect to box using my mobile, So no voice search for me
Thanks a lot for your ROM
A french friend installed your ROM on a Beelink GT1 G912 !!!!!!
You note :- This ROM is based on GT1_111M0 for the 9377 WiFi chipset (S/N beginning with S912 or G912).
If your unit has the AP6255 WiFi chipset (S/N beginning with A912), install the AP6255 UPDATE in TWRP after you flash the ROM to restore WiFi functionality.
if Wi-Fi on GT1 S912 ou G912 doesn't work
, open your box and check your Wi-Fi Chipset reference and install AP6255 UPDATE if necesssary :
My friend discovered into his GT1 G912 box an AP6255 Chipset when opening !!!
Guest
Originally posted by Darren.OL View PostHi Guestร*, has there been any progress in basing this ROM on Nougat, or any other improvements or changes? Thanks!Last edited by Guest; 10 July 2017, 00:49.
Originally posted by Magendanz View PostNo I've had a hard stop on all Android TV 7.1 custom ROMs until we can get functioning TWRP recovery builds for both Amlogic and Rockchip. I'm also about 3 weeks behind on a work deadline, and so haven't had the bandwidth to figure out the problems on my own.Last edited by Guest; 10 July 2017, 00:49.
Guest
Originally posted by Darren.OL View PostOk, thanks for the update. Good luck with your work, I know that takes priority
Guest
Originally posted by scooter2014 View PostAdd in that 7 totally changed the permissions and no working customization tool so think it will be slow till some devs get aroind to it.
I already have a fully working ATV Rom based on GT1_702N0 (7.1.1) just removed, replaced and set permissions all within the device then factory reset.
very tedious way of having to do it.. but I always keep a template of what is removed and added so speeds stuff up in normal situations...
Just have no way to package it for people to flash, i tried going the system.new.dat way like the ota and flashing in twrp while on 6.0 but it just boots to stock recovery..
not sure the system is been converted properly.. Amlogic also got back to me saying, no signed NDA? no customisation tool!
There are currently 1282 users online. 0 members and 1282 guests.
