[ROM] Beelink GT1 / Alfawise S92 TVStock Nexus ROM (Android TV 6.0)
Originally posted by ConnorMcLeod View Post
When i boot the box holding the button with pin tip, it gets stuck to nexus logo, no recovery mode.
Boot the box up normally and press settings button on the remote then go to apps and open the terminal app and type
su
Press enter, then
reboot recovery
Press enter. And will boot twrp
ConnorMcLeodLast edited by tillaz87; 04 June 2017, 18:06.
Originally posted by tillaz87 View Post
Originally posted by mrdigit420 View Post
that definitely looks good, do you have the apk for us to try ?
I had a quick look and see it relies on at least 3 other apk possible more.. i don't think it will ever work on marshmallow maybe with a bit of hacking on 7.0
Here is the beta image for nexus player for anyone interested in trying to hack the apk up to work..
I'm giving it a miss
Or if anyone has a nexus player and just wants to try it out I guess
https://developer.android.com/previe...ashable-images
that sounds like bootloader mode
su
Press enter, then
reboot recovery
ConnorMcLeod
I'm not familiar with all this stuff.
May i try something with adb ? (flashed smartphones couple of time so i can send commands safely).
Also, i can plug ethernet if it can help.
Thanks, now i can enter TWRP, problem is remote doesn't seem to work in there, and the place is "Keep System Read only?" "Swipe to Allow Modifications".
Then (left click and hold) swipe to allow modifications.
Select install zip
Go to the location of the WiFi update.zip, select it and again it will ask to swipe to install, do this and Then reboot.
I'm not sure about adb as it needs to replace the boot.img
here are the apk (apps)
https://drive.google.com/file/d/0B95...ew?usp=sharing
let me know when you downloaded them so i can remove from my google drive, feel free to reupload them.
Are they posted somewhere public I can download them? - So this way you don't have to store them, in order for me to download?
Guest
Minor update today mainly to address the lack of D-pad navigation support in Gboard. Please let me know if you spot any issues.
Changelog (20170606):- Enabled multi-user support.
- Added kernel module for many USB Bluetooth dongles (btusb.ko).
- Reverted to AOSP keyboard, since Gboard just doesn't have the necessary D-pad navigation support. Leanback keyboard is still also available.
- Switched from spoofing the Xiaomi Mi Box to the Nexus Player.
- Removed several libraries that are no longer required.
- Updated for latest Open GApps build (20170606).
There are currently 2053 users online. 0 members and 2053 guests.
