[ROM] Beelink GT1 / Alfawise S92 TVStock Nexus ROM (Android TV 6.0)
Guest
Originally posted by Tweeto View PostLast edited by Guest; 29 April 2017, 23:19.
Guest
Originally posted by tillaz87 View PostWas just wondering what problems you where having with the leanback keyboard ? I was expecting it not to work
Also, I remember that the Leadback keyboard wouldn't work right with Terminal Emulator for some reason.
Guest
Originally posted by mikele View PostDo you know if this rom can fit on TX8 android box (s912 / 9377Wifi chipset) ?
Originally posted by Magendanz View PostI just retested the Android TV Remote app with a clean install of the latest TVStock build, and it worked fine. Did you not even get a paring prompt? And did you confirm that you're running the latest version of the app on your phone or tablet?
Originally posted by Magendanz View PostI haven't tested the ROM on that box, but the TX8 is also based on the q201 reference board and uses the same wireless chipset, so it should work. If your remote doesn't work, you may need to swap out the original OEM remote.conf, though. That will work for everything except cold power-up, since that IR code is hardcoded into the bootloader.
Originally posted by Magendanz View PostOur problem was that Open GApps would remove the AOSP keyboard when installing the Google Keyboard or Leanback Keyboard. If removed, the Droidlogic control would fail to bring up any keyboard when you navigated into an edit box. To be honest, I haven't tested it lately, but it sounds like we could add the Leadback keyboard safely. I'd just need to ensure we didn't get into that scenario before where no text input was possible with the IR remote.
only problem i'm having is with the google boot logo its always screwed up even when saved as R5 G6 B5 ?
Edit: fixed it, needs to be saved as 24bit R8 G8 B8
Here it is if interested exact same as one found on all nexus devices including nexus player bootup.zipAttached FilesLast edited by tillaz87; 30 April 2017, 01:55.
Originally posted by joelkolb View Post
I don't have the answer to why this is but I can tell you my experience and how I worked around the problem. I tried sideloading the APK but on launch I got a message stating something like there was no SU binary and it can't be installed. I then tried the latest release of the TWRP flashable version but I got errors during flash about patching the bootloader if I'm remembering correctly. Then I went back to the v2.46 flashable version which is before all this systemless root stuff became a thing, which I believe was related to the issues I had flashing the current release. That worked. Then I updated to the latest release with the sideloaded APK.You can get the v2.46 flashable zip from the link.
Originally posted by GNex5 View Post
The post at http://freaktab.com/forum/tv-player-...imate-20170224 contains a link to the latest Beelink GT1 Ultimate factory image (GT1_311M0).
After setting up and trying out your brilliant Android TV ROM on a relative's Beelink GT1 for a few days, I encountered something unusual when I took the device back to his house. Shortly after it connected to his WiFi network, I noticed that the connection would drop and reconnect frequently (as in every minute). This was a surprise to me because I experienced no such issues at my house. I had him power cycle his modem / router (Bell Home Hub 2000 AKA Sagemcom F@st 5250) and I restarted the Beelink GT1 multiple times but that didn't solve the problem. I then accessed his modem / router's control panel and noticed that it used a shared SSID for both the 2.4 GHz and 5 GHz wireless bands. After I disabled that option and had the device connect to one of two separate SSIDs, the connection became stable. I think this is worth mentioning here because back when he had the Beelink (GT1_106M0) firmware installed, he did not experience that issue even with the shared SSID for both wireless bands..
Just ran into this today after flashing on my T95U pro. Couldn't figure out why I kept getting connection drops. Separating the 2.4 and 5ghz bands into 2 different SSID solved the issue Thanks!
Also thank you Magendanz for a great rom everything is running great!
Originally posted by Matt_E View PostThis works great on my t95 U Pro even using retroarch so kudos Megendanz much appreciated, just thought I'd give a little back, for anyone who is using this rom for playing games and would like to use a wired ps3 gamepad or one of the DragonRise Gamepad ( usually chinese gamepads that are made to look like n64 or snes controllers).
Simply unzip these two .ko files (hid-dr.ko and hid-sony.ko) from the zip attatched to the bottom of this post to your box and open terminal, cd to the folder you copied them to and typeCode:insmod hid-sony.ko
Code:insmod hid-dr.ko
[ATTACH]n643537[/ATTACH]
Excellent rom!!!! I Installed it on my alfawise S92 and working perfectly! Keep up the great work i'ts awesome. I'd like to ask you..- Added Android TV Remote Control Service, allowing use of any Android phone or tablet as a full-featured voice remote control
i connected my android phone (oneplus 3T) with bluetooth. but then how i can i use it as a remote control????
thank you very much
There are currently 2493 users online. 1 members and 2492 guests.
