[ROM] Beelink GT1 / Alfawise S92 TVStock Nexus ROM (Android TV 6.0)
Guest
I used the Beelink GT1_111M0 official release to refresh OpenGApps and pull SuperSU. (They removed it from the OEM firmware a while back, and there were some folks who thought it should be optional.) I also updated some vendor DRM libraries to enable video playback in "regular" Netflix. (Unfortunately, the Android TV version of Netflix still has no workaround for units without Level 1 Widevine certification.)
Guest
Originally posted by poul50 View Postlast version i noticed that youtube only was in hd not uhd when playing 4K ....in celerons rom it is uhd when playing 4K ....am i right? how about this new release?
Guest
Originally posted by mrdigit420 View PostWhat is "regular netflix " in new update ? does it play hd with regular Netflix app
This fix just allows you to sideload the non-ATV version of Netflix, allowing you to play SD video beyond the 10-12 seconds before you'd otherwise receive a "tvq-pm-100" error.
Guest
Originally posted by BLeaCHeR View PostThere will be a way to change the resolution of the twrp to be a 480ppx rca resolution?
Guest
Originally posted by Arnyto View PostHi Magendanz, can i install this rom on a tx8 android box please?
Can I just say Magendanz this rom is working perfectly for me on my t95U ( sometimes badged as sunvell I think). As I have a 9377wifi module i was not able to use supercelerons rom that was made for my device and I didn't hold out much hope for this but it works perfectly out the box.
Streaming hd TV channels locally with great smoothness at the moment. Just noticed the standard remote isn't working but I'm using a wireless one so that's fine but I also backed up the remote.conf from the previous install so I'm all good.
Great work. Thanks for all the time you put in creating and supporting this rom.
Guest
Originally posted by Matt_E View PostCan I just say Magendanz this rom is working perfectly for me on my t95U ( sometimes badged as sunvell I think). As I have a 9377wifi module i was not able to use supercelerons rom that was made for my device and I didn't hold out much hope for this but it works perfectly out the box.
I've lost SPDIF passthrough in SPMC with latest update (based on 111) (( Is it only me?
Actually with "Passthrough output device" set to "Android, RAW Passthrough" video playback is stuttering (and it took me some time to connect this issue to sound setting). And with IEC there is no sound at all.
There are currently 2317 users online. 0 members and 2317 guests.
