Anyway, the workaround is to install another channel source like Haystack TV, Pluto TV, Bloomberg TV or the Weather Network TV. Once you do that, the Live Channels app will magically reappear.
[ROM] Beelink GT1 / Alfawise S92 TVStock Nexus ROM (Android TV 6.0)
Guest
Okay, Live Channels is now updated to latest version...and the problem wasn't at all what I thought. Apparently, Google added a "feature" in v1.09.419 that hides the Live Channels app in the launcher if there are no channel sources available. This is a horrible UI design, which makes discoverability near impossible, but that's reality for now. What's really odd is that in v1.10.596 they even started ignoring the movie trailer channel provided in Google Movies & TV for Android 6.0 and later. When you upgraded from v1.09.419 the app would just DISAPPEAR from the launcher and the Google Play Store. Really, Google?!
Guest
Originally posted by Darren.OL View Posthow do you update an existing installation of your ROM?
Originally posted by Cinquieme View PostHi again great work and many thanks.
Is this rom suited for Sunvell S912 T95K pro boxes?Last edited by fabien74; 21 March 2017, 21:26.
Thank you for the work on this, exactly what I was looking for, very similar look and feel as my Shield.
I was hoping you could answer a quick question for me please. I loaded this ROM on a Ninkbox Q12, the ROM works great, everything is okay except my remote control. The Ninkbox uses IR and I am not sure if the GT1 does? So, is the code for a IR receiver built into this ROM and I just need to get my original remote.conf, or do I need to load some kind of other packages to get the remote to work? I appreciate your time.
Guest
Originally posted by almstsobur View PostSo, is the code for a IR receiver built into this ROM and I just need to get my original remote.conf, or do I need to load some kind of other packages to get the remote to work?
Hi Magendanz, your Rom is amazing, no pb. But i still have a problem with RGB mode. I must each time i change hmdi source or turn on my TV select 1080p 50 hz and then RGB mode. I don't found yet how can i fix this problem. Am i alone with this bug ? Is a possibity to set definitely the configuration ? Thank for you help.
Guest
Originally posted by loops69 View PostBut i still have a problem with RGB mode. I must each time i change hmdi source or turn on my TV select 1080p 50 hz and then RGB mode.
Install update_GT1_110M0_TVStock-20170319.zip in TWRP on sdcard and I get error string at the beginning: /sbin/postrecoveryboot.sh process ended with ERROR:17
Install successful and nothing - stock on finish. Whats wrong?
A912 2/32Gb
Magendanz Can you help me?Last edited by steeroll; 29 March 2017, 00:11.
Guest
There are currently 2855 users online. 0 members and 2855 guests.
