And that limited Google play was very wired as well, If you please can do a zip fix will be great and appreciated....Thank you so much for your hard work to bring this Rom to us..
[ROM] Beelink GT1 / Alfawise S92 TVStock Nexus ROM (Android TV 6.0)
I installed on my Ultimate GT1 and I can confirmed it's working very well except for 2 things ,wish you sir can help withe it : the notification bar is missing , the key bar at down bar also missing
Guest
Originally posted by Metzo View PostI installed on my Ultimate GT1 and I can confirmed it's working very well except for 2 things ,wish you sir can help withe it : the notification bar is missing , the key bar at down bar also missing
Originally posted by Metzo View PostAnd that limited Google play was very wired as well, If you please can do a zip fix will be great and appreciated....Thank you so much for your hard work to bring this Rom to us..Last edited by Guest; 07 April 2017, 20:38.
Originally posted by Magendanz View PostWell, the status bar and navigation bar are part of SystemUI.apk, which was updated with the version in the Nexus Player so that it's consistent with the Android TV experience. So, that's by design.
And I'm not sure what you're getting at here. Limited Google Play? Do you mean Google Play for Android TV, which limits itself to apps designed to work with Android TV? That would also be by design.
with the mi box updating to nougat beta here https://mega.nz/#!xaZgBCrY!l65tcGGt9...XSmq_sBcZn6uy8 are you planning an update to your rom ?
looks like the stock dpi for android tv is not set in screenshots, it should =320 in build.prop has this been changed since ? just asking so i know if i need to change it.
nice work though this will save me a lot of time for a change, so thanks for sharing this mate.
Edit:
Just looked its ro.sf.lcd_density=240 stock is 320. coming from nexus player then shield tv 240 just looks a bit odd to me.
Also here is the stock .bpm nexus splash screen (bootup) I noticed its not been changed just thought i would share if interested
i made it for something similar i done a few month back. straight swap in the logo_res folder for anyone else interested. (using customization tool)
http://s000.tinyupload.com/download....79242327138244
or
http://s000.tinyupload.com/?file_id=07139114726792423271Last edited by tillaz87; 18 April 2017, 02:58.
Guest
Originally posted by tillaz87 View PostJust looked its ro.sf.lcd_density=240 stock is 320. coming from nexus player then shield tv 240 just looks a bit odd to me.
Cool, some tv apps might have issues with wrong dpi, i can easily change it though like you say. i want to look at getting the LeanbackIME.
as again its something i'm used to from shield
was not an issue on the S905X device i had but guessing not here ? not got my GT1 yet so wouldn't know
Edit:
Could also remove xbmc_addons.sh and installApks.sh from /bin folder
its how they install their crap ware to data partition after factory reset on stock rom. could be useful if you want to add your own stuff i guessLast edited by tillaz87; 18 April 2017, 04:14.
Guest
Originally posted by tillaz87 View PostCool, some tv apps might have issues with wrong dpi, i can easily change it though like you say. i want to look at getting the LeanbackIME.
Originally posted by tillaz87 View PostCould also remove xbmc_addons.sh and installApks.sh from /bin folder
I'm ok with .smali will have a look when i get my box see if i can work around it
its not an issue on the 6.0.1 builds for S905x devices or at least mine, so going to diff some parts see how much is changed
if i can find the references in the smali i could change it to force LeanbackIME rather than LainIMELast edited by tillaz87; 18 April 2017, 07:00.
Originally posted by Magendanz View PostYou'll need to fully remove the DroidLogic system control from the framework to do this
is it just what logcat showed ? If you could point me in the right direction where droidlogic system control was referenced would be a big help as I don't have the gt1 yet.
Edit:
Found references to this in smali from droidlogic-res.apk anywhere else i should be looking ?
Guest
Originally posted by BLeaCHeR View Post[USER="82661"]...do you know if your rom can work on a MXIII - G II?
There are currently 2827 users online. 0 members and 2827 guests.
