[ROM] Beelink GT1 / Alfawise S92 TVStock Nexus ROM (Android TV 6.0)
Guest
Originally posted by lefteris82 View PostI connected my Android phone (oneplus 3T) with Bluetooth, but then how i can i use it as a remote control????
Guest, Are you gonna play with Nougat?
Reposting what KAA posted in alvatech's forum
GT1 Android 7.1
https://beelink-my.sharepoint.com/personal/...KIj3x5dGHe6tM60
Originally posted by Magendanz View PostWell, assuming you've got the Android TV Remote Control app installed on your phone, you just need to be on the same local IP network (WiFi or Ethernet). Bluetooth paring isn't needed.Looking forward for the android 7 based ROM .
Does anybody have any idea where I can find some game controller drivers for these boxes. I've been trying to find hid-xinmo.ko for months with no joy I found many others that worked for other controllers such as the PS3 and dragon rise controllers I posted in this thread and they were originally for the s908 but worked well with these s912 boxes.
Hi Thx for your firmware i try to install it on my box but now i have a bootloop =( box only reboot on twrp as i say on my post (http://freaktab.com/forum/tv-player-...op-after-flash)
Anyone already see this problem and can help me plz ?
Guest
Originally posted by lioram View PostI connect my bluetooth remote on the GT1, it's working fine when paired the remote but when i shutdown the remote is not anymore detected...
Originally posted by mikele View PostDo you know if this rom can fit on TX8 android box (s912 / 9377Wifi chipset) ?
Also, I have issues in a few apps with certain elements of the UI not displaying but I'm not sure if that is an issue caused by running this ROM on this box.
But besides some minor annoyances that can be easily overlooked, this ROM works great on the TX8 Max and should work great on the TX8 as well.
Originally posted by joelkolb View Post
I have a TX8 Max running this ROM very well. That box is also based on the q201 board. I believe the only difference between the TX8 and the TX8 Max is the Max has more RAM and a different WiFi chip. I had to flash the 6255 WiFi driver package from the OP to get WiFi working. You wouldn't even need that. The issues I have are that the included remote didn't work for me after flashing. If you backup your remote.conf file from your stock ROM you can replace it after flashing this ROM to get it working again, mostly. You still won't be able to power on the box from a cold state using the remote, though. This I believe is due to the code for the Beelink remote's power button being coded into the bootloader, which is separate from the codes in the remote.conf file. I had the idea of flashing the stock ROM back to get the stock bootloader back and then using DD to back it up and restore it after re-flashing this ROM but all that is a risky proposition.
There are currently 1398 users online. 1 members and 1397 guests.
