[ROM] Beelink GT1 / Alfawise S92 TVStock Nexus ROM (Android TV 6.0)
Guest
Could someone on linux please run and extract this for me, zip it and upload? its only 13mb
Nexus Player binaries for Android 7.1.1 (NMF27D)
https://developers.google.com/androi...ers#fugumob30m
Launcher, Remote, TV Google Link
I'm trying to find out what library I'm missing for AtvRemoteService.apk on 7.1.1
Originally posted by tillaz87 View PostCould someone on linux please run and extract this for me, zip it and upload? its only 13mb
Guest
So, are you making changes to the system partition as you're running from it? I would have thought that many files would be busy, not allowing changes or replacement. And is the plan to just distribute a raw system partition image, rather than an Amlogic burn package or system update file? (Both these would require fixes to make_ext4fs, which doesn't seem to be handling file contexts in Nougat correctly, even when converted from the new bin format).
Originally posted by Magendanz View PostSo, are you making changes to the system partition as you're running from it? I would have thought that many files would be busy, not allowing changes or replacement. And is the plan to just distribute a raw system partition image, rather than an Amlogic burn package or system update file? (Both these would require fixes to make_ext4fs, which doesn't seem to be handling file contexts in Nougat correctly, even when converted from the new bin format).
I edited my post above as didn't want to say anything untill all is 100% working. Will pick up after the weekend and hopefully get it uploaded not long after.Last edited by tillaz87; 20 July 2017, 13:08.
I have made a work around that appears to be working so far. I still have a few things to look at but made good progress with one of the 2 problems.
I edited my post above as didn't want to say anything untill all is 100% working.. Will pick up after the weekend and hopefully get it uploaded not long after.
Edit:
Enabled the new recant apps panel in nougat ATV that beelink have disabled.. double pressing a home button opens it, long hold triggers assistant.
AtvRemoteService.apk not working.
have etc/permissions/com.android.media.tv.remoteprovider.xml
framework/com.android.media.tv.remoteprovider.jar
Logcat:
Code:Ignoring atv remote provider service because the package has not been set and/or whitelisted
Edit: Just seen beelink posted 7.1.2 yesterday, nice of them..Last edited by tillaz87; 22 July 2017, 00:40.
thanks for great work!This firmware is very good.
but i came up with some problems.
For the status bar and nav bar came back,I restored the 113M0 official's systemUI.apk,and then i had status and nav bar.
but in some softwares,the "TITLE BAR" seems like not intact.
like this soft in my phone,the two icons can't be senn in my box's same software,so i can't click them too.
some other software had the same problem.
maybe systemui.apk only is not enough?
You may only view thumbnails in this gallery. This gallery has 1 photos.1 Photo
Guest
Yes, this is a generic problem with the app bar (a.k.a. action bar) running on Android TV. You've probably also noticed that the Up (<) button also doesn't work when you click on it. I've been searching for a clean fix, but so far the only workaround is to revert to a non-Android TV build. This is listed under "known issues" on my original post.
Hi @Magendanz!
Im trying to flash the new GT1_703N0_AP6255.img over yours but am falling short when trying to connect via usb, It seems that TWRP has replaced the mode where I would boot from usb using the pin trick, therefore usb burn tool cannot recognize the device. Any assistance would be greatly appreciated!
EDIT: Disregard, I was using the wrong USB port, PLEASE NOTE THE SIDE PORT IS THE SERVICE USB PORT ON GT1
There are currently 4715 users online. 1 members and 4714 guests.
