TVStock variant includes:
- Open GApps TVStock Package
- All contents of the Nano Nexus variant
- Open GApps Nano Package
- Google Now Launcher (replaces Lighthome Launcher)
- Google Chrome Browser (replaces AOSP Browser)
- Google Legacy Camera (replaces AOSP Camera)
- Google Desk Clock (replaces AOSP Desk Clock)
- Google WebView (replaces AOSP WebView)
- File Manager v3.0.0 and Sound Recorder v6.0.1 from CyanogenMod/LineageOS
- Terminal Emulator for Android v1.0.70 by Jack Palevich
- TWRP Recovery 3.1.1-0 from TeamWin
- Enabled multi-user support.
- Added kernel module for many USB Bluetooth dongles (btusb.ko).
- Reverted to AOSP keyboard, since Gboard just doesn't have the necessary D-pad navigation support. Leanback keyboard is still also available on TVStock.
- Resolved blocking issue with WiFi setup in SetupWraith that wouldn't allow progress past language selection.
- Removed several libraries that are no longer required.
- Updated for latest Open GApps build (20170607).
- New Nexus logo splash and device name of "Nexus M8S".
- Added Leanback UI sounds.
- Modified build.prop to spoof the Nexus Player (fugu), which should circumvent some device checks.
- Modified build.prop to enable 4K output in YouTube for Android TV.
- Modified several UI settings (inc. animations & themes) in the framework to match those on the Nexus Player.
- Removed GlobalKeyInterceptor.apk and GamepadPairingService.apk, which are specific to Nexus Bluetooth remotes.
- Added kernel modules (device drivers) for Sony PS3 and Dragonrise USB HID game controllers.
- Updated for latest Open GApps build (20170526).
- Updated to TWRP Recovery 3.1.1-0.
- Resolved issues with Google Keyboard and Google Leanback Keyboard, and so both are now available to set as default IME.
- Added SELinux security contexts during sparse file system creation.
- Fixed keyboard focus issue on first screen of Setup Wizard (SetupWraith).
- Fixed permissions issue with CanvasPackageInstaller.apk by signing with platform key.
- Fixed bug causing pop-up on first launch to select whether you want to use the setup wizard or skip directly to the Home Screen.
- Enabled "SKIP" in network selection screen of setup wizard. (This could be useful if you haven't installed wireless driver yet.)
- Removed SuperSU as preinstall. (Build is still rooted, but now have option of installing via Google Play Store.)
- Restored TV Settings to Nano variant, just for consistency with other Nano variant releases..
- Updated to TWRP Recovery 3.1.0-0.
- Updated with latest Open GApps build (20170425).
- Updated TVStock with latest Live Channels app for Android TV 5.1. (To make visible in launcher, add a channel source like Haystack or Pluto TV.)
- Updated TVStock with SystemUI app from the Nexus Player (Fugu), which is more appropriate for Android TV.
- Fixed bad API call in ATV Remote Service. Android TV Remote App should now function from your phones and tablets.
- Fixed permissions that were preventing Kodi from downloading on Google Play Store for Android TV.
- Deodexed ROMs and updated to latest Open GApps build (20170317).
- First build of TVStock variant running Android TV. (See known bugs below.)
- Latest official Mini M8S ROM build (rv105L3) stripped to Android stock bits and latest Open GApps build
- New Amlogic S905 boot logo (replaces generic Google TV)
- Stock Android boot animation
- Exposed regular Settings app in launcher. The Leadback TVSettings.apk is renamed "TV Settings" (and removed in Nano variant).
- Switched Nano display density from DENSITY_HIGH (240dpi) to DENSITY_TV (213dpi), which gives more screen real estate and fixes label clipping in Google Now Launcher.
- Updated icons and layout of navigation bar to center main three buttons and provide better spacing.
- Removed underlying Amlogic ROM dependency on AOSP WebView.
- Changed build characteristics to report as "tablet", instead of "mbox" to address some app compatibility issues.
- Included OTA updaters that can be installed in TWRP without wiping user data.
- Cast service can't get a Cast device cert through ClientAuthSigner except when casting from Chrome browser.
- To make Live Channels app visible in launcher, add a channel source like Haystack or Pluto TV.
- Action bar Up (<) button events are ignored. To work around, use Back button on remote, Esc on keyboard or right-click on mouse.
- Unable to add VPN profiles in Settings.
- Nano Variant: BURN PACKAGE (668MB IMG file), OTA UPDATE (365MB ZIP file)
- TVStock Variant: BURN PACKAGE (752MB IMG file), OTA UPDATE (424MB ZIP file)
- Flash burn package with Amlogic USB Burning Tool v2.0.8 or BootcardMaker v2.0.0.2
- This ROM is based on the Mini M8S rv105L03 ROM, but it also works without modification on the Beelink Mini MX III. In fact, most AMPAK wireless chipsets seem to be supported, since they emulate the Broadcom BCM4354.
- The OTA update is signed, and so can be installed in the Update & Backup app, the stock recovery, or TWRP. It's designed for incremental updates, since user data is preserved. Bootloader, logo, boot partition and system partition are included, but not recovery.
- Flash ROMs at your own risk and always remember to back up your data first. The burn package includes a factory reset
- Maarten Fonville at Open GApps
- AbduL for Amlogic TWRP Recovery
- LineageOS Project
- Pure Nexus Project
- Jack Pelevich
- Your support is always appreciated! Just click here.
