[ROM] Mini M8S / MX3 Nano and TVStock (Android TV) Nexus ROMs
Guest
Guest
Originally posted by Yves-Marie View PostHi, it seems imposible to un install an app installed from playstore ( T95N 2G/8Go S905) . I use the Last version (20170319) , TVSTOK. Not an upgrade. The same problem was in the previous version.
Originally posted by Magendanz View PostSorry, I can't reproduce this problem. I just installed and uninstalled two apps (KODI & VLC) with no problems on the latest TVSTOCK.
Uninstall through google play store works : When an app is installed' there's an option on the description page to launch or uninstall the app.
but i try to uninstall app through Settings > Applications . Clearing cache, clearing data works but uninstall application seems to do nothing.
So it's an half problem bécause it works through play store
Tips : To create a banner on Startup page for an application not recognized as "AndroidTv Compatible" (Like CCleaner) , i simply use this site http://atvlauncher.trekgonewild.de/ which create a little signed apk only containing a banner and a shortcut
. Tested with CCleaner ( "com.piriform.ccleaner"). no problemLast edited by Yves-Marie; 27 March 2017, 10:20.
Guest
Originally posted by vutiendung86 View PostI have installed applications from my SD card but I have problems with removing them. Is there any way to overcome this problem?
Originally posted by Magendanz View PostApparently, there's a problem removing them from Settings->Apps, but it works when you remove them from the Google Play Store. I'm looking into the cause.
1. Temporarily, I found a way to remove applications easily through the TIANIUM backup application. Everything is ok
2. The temporary sleep feature of my mini m8s pro box has been gone since I installed the TV stock rom. It's really very useful because my box has no power button. Can you help me?
Thank you.
Hello Magendanz
After a while using the TV stock rom on my mini m8s pro box is very good, android tv interface is very beautiful. Applications run very stable. However, I have a problem with the temperature of the box. When running for long periods of time, it often gets hot and turns itself off. I am really concerned about this. Do not know if you have a problem like me? I do not know what the cause of this problem is and how to fix it. Please help me if you can? Thank you!
Guest
Originally posted by vutiendung86 View PostI have a problem with the temperature of the box. When running for long periods of time, it often gets hot and turns itself off.
Hi Magendanz
I have a few questions with the tv mini m8s pro (T95N)
1. Does the T95N have a CMOS battery? I encountered a few problems.
2. The sleep feature does not work with rom TVStock (20170319). With the old rom, it has a sleep function.
3. Sometimes, my box does not automatically update the time. I have to turn on Wifi to update so it's very annoying.
4. Wifi is very poor when compared to rom stock. Is there a way to fix it?
Thank you very much!
Guest
Originally posted by Fabbione View PostIs it 1080p available on netflix with this ROM, with the other feature of android TV?
Hi Magendanz,
Very good job with this rom, I tried it on my beelink mxiii (s905) because I wanted to really do everything with only a remote (waf issues lol) which can not be done with regular android.
But actually it created issues I haven't had before... I can only connect via wifi, it doesn't seem to see my rj45 cable connected : quite a problem for "real"hd movies which lag on wifi. Even with the original remote.conf in etc I can't get the remote to work. The framerate switch is perfect but audio passthrough doesn't work for me.
I keep an eye on here in case of a update but I get that you have a lot of things to do, thanks again for the work done.
Guest
Originally posted by Deshi View PostI tried it on my Beelink MXIII (s905) .... I can only connect via wifi, ...I can't get the remote to work.
Hello,
if i want so install the TVStock OTA UPDATE (430MB ZIP file) about the Update & Backup App i get this problem: E: Cannot load colume /misc!
So what to do ?
There are currently 4786 users online. 1 members and 4785 guests.
