[ROM] Mini M8S / MX3 Nano and TVStock (Android TV) Nexus ROMs
Guest
Originally posted by Magendanz View PostOpen File Manager, enable Root Access in settings, and then open the System directory. From there, just click the build.prop file to read it.You may only view thumbnails in this gallery. This gallery has 1 photos.1 Photo
Originally posted by Magendanz View PostWhat wireless chipset does your device use?
Hi. How can I know that information?
How can I find out which wireless chipset is used by my device?
It's a mini m8s
Guest
Originally posted by manal_vedder View PostHow can I find out which wireless chipset is used by my device? It's a mini m8s.
Originally posted by Magendanz View PostWell, I started with the stock OEM firmware for the Mini M8S, so it's probably not that you're missing wireless drivers. Can I assume you've enabled Bluetooth in Settings?
Yes friend, the first thing I did was enable the bluetooth. can you help me please :-(
Guest
Originally posted by manal_vedder View PostYes friend, the first thing I did was enable the bluetooth. can you help me please :-(
Guest
Originally posted by kokjin99 View PostIs this mean not able to use the ROM? thanks
Guest
Originally posted by guybre View PostHello, i have the same problem as gawin. I've succesfully installed the nano package but i'm stuck with the TV Stock when choosing the language
Guest
Originally posted by lomidrevo2 View PostHi, TV Stock ROM is almost perfect. I really missing to play youtube video from my mobile phone via youtube application. I think this is manageable by Google Cast. Can you check this in future releases if this is possible to be working.
There are currently 3799 users online. 0 members and 3799 guests.
