regards
[ROM] Mini M8S / MX3 Nano and TVStock (Android TV) Nexus ROMs
Guest
Originally posted by bysimba View PostYes, core uses s812-h. Do you now where I can fins something?
Guest
Originally posted by bysimba View PostOK i tink is time to change for another one,i was trying chance the build.prop and habe sucess but the live channels dont Work i tink becose lollipop
Guest
With new 2/16GB M8S Pro units running Android 7.1.1 now selling today for less than $50USD, I expect the fire sales to clear Android 6.0.1 inventory soon. It's hard to justify spending time to resurrect an old KitKat box.
Guest
Originally posted by kokjin99 View PostCan device M9 plus use this ROM?
Originally posted by Magendanz View PostIt's difficult to say without access to the stock firmware. Check your build.prop and look for the "ro.product.board" property. If it's "p200_2G", then the odds are good because they're based on the same reference board. OEMs sometimes swap out different wireless chipsets or change remote control IR codes, but the foundation is the same.
Guest
Originally posted by manal_vedder View PostWhen trying to disintegrate an apk is not able to carry out, fails to uninstall any apk. How can I correct that?
There are currently 1582 users online. 0 members and 1582 guests.
