Could you please tell me which rom / modifications you used to install ATV rom on Mini Mx V1 ?
I can't manage to make the rom on this thread work. I have installed the one for MXQ, fixed the remote.conf but the box is laggy, has no wifi and can't be started / shutdown with the remote (only by plugin or removing AC cable)
You seem to have a working version on the Mini MX so please tell me how you managed to get it
For your Widevine problem, I think there's no miracle solution as this is a hardware problem.
Thanks for your help mate !
