[ROM] Mini M8S / MX3 Nano and TVStock (Android TV) Nexus ROMs
#215.1Guest commented03 December 2017, 22:31Editing a commentOneDrive is just being flaky. In the interim, try the archive site here: http://freaktab.org/3~f
Magendanz: I want to update my p200-based box with your ROM but it's a generic model and I'm not sure about wifi chipsets, etc. What can I do to identify my components? I posted this question in another thread since it's a more generic topic. http://freaktab.com/forum/tv-player-...droid-box-help
Originally posted by Carontes View PostHello Guest , I've installed your ROM into my tv box (MiniMX Version 1) and I've fixed wifi connection since its wifi chip is ap6330 (I have to fix bluetooth, so when I'll finish I can give it to you so you can make an update or post the zip here). I've installed the Android TV version but I have a doubt, why I can't find on the Google Play Store some games that I was able to found with the stock ROM? Can I install/upgrade opengapps.org apps flashing them? I've flashed Android TV version thinking I could had been able to download games like Golden Axe (with the stock ROM it wasn't visible on the store) but now I can't see it either, why don't you change the "fake" name of this version from nexus 10 to nvidia shield? Could it works? Thank you.
Carontes, I also have a Mini MX V1 and I can't manage to instal ATV rom on my box. II've tried all roms for s905 devices on the forum but best thing I got (with MXQ rom) is to get to language choice but buggy, I can't chose language and go further. In addition, the remote doesn't work.
All the other roms, including the one in this thread, are crashing during flash with usb burning tool at 2%
Mabe you can help me just telling me which version of the rom you intalled on your Mini MX ?
Many thanks to you two !
Hi community
I tried to flash my Beelink MiniMX III with the Nexus Rom. It went ok, but the remote control wasn't working at all (I was blocked on the 1st screen where you need to choose your language).
I then decided to try the Nano version in case it would fix the remote issue, but it went wrong, and now my box only shows a black screenTried to install again the stock firmware, but the upgrade won't start, the screen stays black, and I can't manage to get my box recognize in the USB Burn tool, but maybe I'm doing something wrong...
Does anyone here know how to fix this issue?
Many thanks
I've made some progress but still can't start Netflix. Now the error is "error (-100)". If someone knows how to fix it please text the solution. Thanks.
I can watch Netflix but only with the smartphone/tablet app, not with the AndroidTV version. The last version of the app that works is the 4.16.1 taken here https://www.apkmirror.com/apk/netfli...15145-release/Last edited by Carontes; 15 January 2018, 16:50.
There are currently 4890 users online. 0 members and 4890 guests.
