[ROM] Mini M8S / MX3 Nano and TVStock (Android TV) Nexus ROMs
Guest
Originally posted by Jonh_Dimagio View Post
Guest
Okay, I was finally able to reproduce it on my end...but only when I had no connectivity. Plugging in Ethernet allows it to proceed past the language selection, and wireless setup is available once you make it to the Settings or TvSettings apps. I'll look into this over the weekend, as it seems to have something specifically to do with WiFi configuration in SetupWraith.
Originally posted by Magendanz View PostOkay, I was finally able to reproduce it on my end...but only when I had no connectivity. Plugging in Ethernet allows it to proceed past the language selection, and wireless setup is available once you make it to the Settings or TvSettings apps. I'll look into this over the weekend, as it seems to have something specifically to do with WiFi configuration in SetupWraith.
Guest
Changelog (20170607):- Enabled multi-user support.
- Added kernel module for many USB Bluetooth dongles (btusb.ko).
- Reverted to AOSP keyboard, since Gboard just doesn't have the necessary D-pad navigation support. Leanback keyboard is still also available on TVStock.
- Resolved blocking issue with WiFi setup in SetupWraith that wouldn't allow progress past language selection.
- Removed several libraries that are no longer required.
- Updated for latest Open GApps build (20170607).
Originally posted by Magendanz View PostChangelog (20170607):- Enabled multi-user support.
Guest
Originally posted by Agronur View PostCan I use this image for my beelink mini MX iii (s905 - 2/16)
UPDATE: Sorry, I forgot that was using the Mini M8S remote. (I've got WAY to many of these boxes cluttering my office.) To use the original Mini MXIII IR remote, see below. Alternatively, you can use a Bluetooth universal remote, which is what I recommend.Last edited by Guest; 08 June 2017, 01:42.
Originally posted by Agronur View PostThanks for your effort. Can I use this image for my beelink mini MX iii (s905 - 2/16)
I've made a patch for this based on Magendanz (very good) work.
I'm uploading files (3 files)
- Magendanz Android TV Stock MiniMx3 untouched
- 20170607 update modified with the remote patch for Mini MX 3 included
- remote patch solo
Unfortunately the remote mouse function doesn't work...
I'm not a developer, what i've done is DIY stuff based on Magendanz work...
(The stock firmware MINI MXIII_107L1_0425 is required to install those ROM)
Tips: Because the firmware of this box is a shit...If you want to use Kodi properly (without video stutter and poor WIFI) i suggest you to install LibreElec on SD card (dual boot, with LibreElec you can choose to reboot from internal)
Guest
There are currently 1841 users online. 1 members and 1840 guests.
