[ROM] Mini M8S / MX3 Nano and TVStock (Android TV) Nexus ROMs
Guest
Originally posted by lomidrevo2 View PostAnd also please remove /system/bin/preinstallapps.sh script, because it is looking for /system/media/preinstallapps.tar which is not there and then it is running in loop and eating cpu.
Hi, thanks for this ROM Magendanz
I managed to install this ROM on Mini MX 3 with USB cable male/male only and i had to flash stock firmware before(perhaps the reason why sd card method didn't work) for information.
Unfortunately stock firmware is buggy, wifi is weak and video stutter...That's the reason why i wasn't on stock firmware (i was on minix port http://freaktab.com/forum/tv-player-...-twrp-recovery)
I have installed LibreELEC ( http://kszaq.libreelec.tv/s905/8.0.1l/ ) too on SD card and i have no problem with wifi and video stuttering...
Is there a way to use another firmware or else in your ROM to avoid these problems ?
Guest
Originally posted by HiBoU974 View PostIs there a way to use another firmware or else in your ROM to avoid these problems ?
Unfortunately, I ran into a bunch of issues with the MX3 transition, enough so that I set it aside. I don't know that it would have addressed your performance concerns, but I never really got that far. As it is, I'm hard pressed to spend any time maintaining the Android TV 5.1 boxes given how dated they are, so I can't promise that I'll even revisit the MX3 transition.
Originally posted by Magendanz View PostWell, the only p200_2G boxes I have are the Mini M8S and Mini MX3. I'm currently building on M8S rv105L03, but had planned to move to MX3 107L1 because the Beelink stock firmware is generally better maintained (by Netxeon) than from other sources. (In fact, I started the p212 custom ROMs on Mini M8S II and moved them to the Mini MX3 II and was pretty happy with the result.)
I think i bought the worst box lol...In fact for wifi issue, streaming 1080p video > 8 Go causes buffering and for video stuttering they append on youtbe, iptv and Kodi... (it's micro stuttering but very annoying)
I think i will buy a mi box but i'm disappointed with this beelink, "on the paper" it has all a box need. In fact it's hardware capable but not software :/
Best regards
Guest
Originally posted by HiBoU974 View PostI think i will buy a mi box but i'm disappointed with this beelink, "on the paper" it has all a box need. In fact it's hardware capable but not software :/
Right now the sweet spot seems to be Android TV 6.0.1 running on S905X or S912, and you're perfectly well suited with a 2G/16G config with DDR3 RAM....if you can find a real Android TV custom ROM for it. I just picked up a 2G/16G S905X (p212) box at Walmart for $32, and that will have Ethernet and MicroSDXC support (which the Xiaomi Mi Box doesn't). Soon we'll have real Android TV 7.1 running on s90x and RK33xx boxes, but I'm not convinced that the Nougat releases will perform any better than Android 6.0.1 because of them dropping the hardware acceleration codecs.
There's always going to be something better around the corner, but I'm still pretty impressed with what $32 will buy you. You just can't count on any software support other than what you'll get here on FreakTab.com.
Guest
I want to extend a special thanks to tillaz87 for all the work he did diffing framework resources, and I think today's update shows a level of UI polish that was missing before. (Now, if we can just figure out a way to reliably get certs for Google Cast Receiver, I'll consider this project pretty much complete.)
Here's a quick summary of the changes. As always, please let me know right away if you spot any issues.
Changelog (20170526):- New Nexus logo splash and device name of "Nexus M8S".
- Added Leanback UI sounds.
- Modified build.prop to spoof the Nexus Player (fugu), which should circumvent some device checks.
- Modified build.prop to enable 4K output in YouTube for Android TV.
- Modified several UI settings (inc. animations & themes) in the framework to match those on the Nexus Player.
- Removed GlobalKeyInterceptor.apk and GamepadPairingService.apk, which are specific to Nexus Bluetooth remotes.
- Added kernel modules (device drivers) for Sony PS3 and Dragonrise USB HID game controllers.
- Updated for latest Open GApps build (20170526).
- Updated to TWRP Recovery 3.1.1-0.
- Resolved issues with Google Keyboard and Google Leanback Keyboard, and so both are now available to set as default IME.
- Added SELinux security contexts during sparse file system creation.
- Fixed keyboard focus issue on first screen of Setup Wizard (SetupWraith).
- Fixed permissions issue with CanvasPackageInstaller.apk by signing with platform key.
Originally posted by Magendanz View PostYou can still install this on the Mini MX3, but you'll need to install the wireless chipset driver patch. This isn't my patch, so you'll have to dig around to find the link.MINIX U1, MINI MXIII, MINI MXIII II, GT1, SEA I
I've used this patch http://freaktab.com/forum/tv-player-...-twrp-recovery but i'm not sure this is this one i have to use...
I've tested it but i'm facing a boot loop right after choosing language, each time i choose a language it ask me again to choose language..
I've used this patch http://freaktab.com/forum/tv-player-...-twrp-recovery but i'm not sure this is this one i have to use...MINIX U1, MINI MXIII, MINI MXIII II, GT1, SEA I
Guest
Originally posted by HiBoU974 View PostI've tested it but i'm facing a boot loop right after choosing language, each time i choose a language it ask me again to choose language..
Originally posted by Magendanz View PostSounds like SetupWraith is crashing trying to connect to WiFi. That driver patch probably isn't right for your hardware.
There are currently 5335 users online. 2 members and 5333 guests.
