[ROM] Mini M8S / MX3 Nano and TVStock (Android TV) Nexus ROMs
Guest
There are no APKs distributed, only the OTA update (.ZIP file) and Amlogic burn package (.img file). Instructions on installing these are in the first post.
Originally posted by Magendanz View PostThere are no APKs distributed, only the OTA update (.ZIP file) and Amlogic burn package (.img file). Instructions on installing these are in the first post.
Guest
My guess is that the APK you tried to install was targeted for an older SDK and the Android 5.0 package installer couldn't handle it. I did confirm on my hardware with a clean flash that I can sideload apps from the SD card using File Manager and downloaded from the Chrome browser.
Originally posted by Magendanz View PostMy guess is that the APK you tried to install was targeted for an older SDK and the Android 5.0 package installer couldn't handle it. I did confirm on my hardware with a clean flash that I can sideload apps from the SD card using File Manager and downloaded from the Chrome browser.
I'm not sure about this. I downloaded the KODI 17.apk file on the kodi.tv web from my computer and put it on the SD card but still got the Parse error. When I loaded the browser chorme of the box, the message is not found SD card path. It's hard to understand.
P / s: I am using rom MiniM8S_rv105L03_TVStock-20170304.img
Guest
Originally posted by vutiendung86 View PostI'm not sure about this. I downloaded the KODI 17.apk file on the kodi.tv web from my computer and put it on the SD card but still got the Parse error. When I loaded the browser chorme of the box, the message is not found SD card path. It's hard to understand.
P / s: Last time when up rom I used USB Burning Tool v2.0.8 so I do not see any error. Should I try up rom 20170319 build .IMG? I would like to ask if P200 - 2G and P201 - 2G are two identical products but different factory? I think my T95N box is P201 - G.
Thank you!
Guest
The "T95N-2G" that I had (and have since given away) reported it's board as a p201_tn2 in the build.prop...which is very unusual. Honestly, I don't know if it's compatible with the p200_2G, but it's probably worth a try to update to the latest release using the burn package. (Strangely enough, I'm more strict on the compatibility checks on my OTA updater than Amlogic is in USB Burning Tool.)
I'm also getting Parse errors after downloading KODI 17 for Android from the KODI downlad page. This is happening on multiple downloads. Eventually I installed APK Editor Pro and went into the file to see what the issue was. When I opened the files the APK was blank with the header entries 'hello' and 'bruhahaha'. Any ideas where to get an uncorrupted version of Krypton.
Guest
Okay, at least I know that the problem isn't on the ROM side of things.
I gave you a link in my reply above to the official ARM release of KODI 17.1, but you can always get the latest from their download page.
Great. Thank you Magendanz!
Everything is fine with my mini m8s pro box right after I Up rom TVStock 20170319 with USB Burning Tool v2.0.8 software. I have successfully installed KODI 17.1 from google play, the .apk files on the memory stick and USB are also installed without any difficulty. I'm very happy. Again thank you very much for the dedication to the community.
Originally posted by Magendanz View PostOkay, at least I know that the problem isn't on the ROM side of things.
i been using this wifi driver , it much more better than stock driver by beelink....thanks
MiniMX3_WiFi_Driver_Patch_FINAL.zip
MINIX U1, MINI MXIII, MINI MXIII II, GT1, SEA I
There are currently 2836 users online. 0 members and 2836 guests.
