[ROM] Mini M8S / MX3 Nano and TVStock (Android TV) Nexus ROMs
Originally posted by Magendanz View PostUnlike apps that you install via the Google Play Store, the OpenGApps from Google are preinstalled in the /system directory. You can uninstall them manually by deleting their directories in /system/app or /system/priv-app, which can be done in CMFileManager after setting Root Access.
Ok thanks a lot, what happens is that I just did flash from the atv rom I did not flash the gapps, what I did was go adding external programs not from google play. Such as mx player, arena4viewer, xmtv, etc, some of which I can not uninstall. I will try to use the method that the folder system. Best regards and thanks for your prompt response. Great work
Guest
Originally posted by manal_vedder View PostI have this other android tv box, is it possible that I can put or flash the android tv rom?
Guest
Originally posted by aenema24 View PostHi ! i have a generic box that have amlogic s905 and the board is p201 it has 1gb ram an 8gb rom, should the rom work on it?
Guest
You may have picked up that the most important factor on whether a custom ROM is compatible with a particularly device is what model Amlogic reference board they used. This can be found in the build.prop file recorded as the "ro.product.board" property. For descriptions of these reference boards, I've created a new topic here.
Guest
Originally posted by kokjin99 View PostSorry i'm new to the tv box. how to check the ro.product.board? is it using software or check the physical box?
Originally posted by Magendanz View PostNo, this is for the p201_2G and it's not compatible with the regular p201 reference board. I have one of these older p201 boxes lying around and have considered building Nano and TVStock for it, but it will be a few weeks.
Originally posted by Magendanz View PostThat's an S905X box, which uses the p212 reference board. This one won't work, but you should be able to install my Beelink Mini MX3 II/M8S II custom ROM.
okay. And where can I download that personalized rom ??, please can you indicate me. best regards
Guest
Originally posted by aenema24 View Post...the problem is that my tv box do not install android tv app (Like Netflix Android TV app) it says is incompatible and i have to use the regular phone version and is really annoying to use, you know what i can do?
Originally posted by manal_vedder View PostDear. I managed to solve it, the problem was that I had corrupted the image, but I went down again and I followed the steps again and made it work, I was super good. I really appreciate your work as it works wonderfully even loading everything faster. Wow
A query exists some way to be able to install apk netflix leanback type and that this function even if only in sd or hd quality, but that is leanback type
friend. One thing I just realized is that after flashing my device, now the bluetooth does not work, is there any solution to that?. please please
Guest
Originally posted by minixfreak View Post...there is a 5.1.1 for mxq s805 posted on 4pda forums and tested it ... works good your could strip it down and make atv for s805Last edited by Guest; 28 April 2017, 23:12.
There are currently 5510 users online. 2 members and 5508 guests.
