[ROM] Mini M8S / MX3 Nano and TVStock (Android TV) Nexus ROMs
Guest
Originally posted by HiBoU974 View Post
Guest
Originally posted by manal_vedder View PostDear. Install the latest update and try to connect my ps3 chinese joysticks through apax sixaxis throw me error. Says KILLED and there is no way it works. You can help me since with the official ROM of the equipment worked very well that apk to connect the joystick of Chinese ps3
Originally posted by Magendanz View PostI don't have that hardware, but you can try different kernel modules and test them by placing in /system/lib/modules. When you have something working, please message me with a link and I'll update the custom ROM.
Originally posted by manal_vedderReal sorry for me this is complicated since I am new to this. I do not know what you mean by testing modules in the kernel. I can only tell you that my android tv box is mini m8s. please help. I would not want to return to the original ROM of my device. please help.
And more here. http://freaktab.com/forum/tv-player-...-roms-tools-bx
Mini m8s. In title will work on your device.Many devices now mk902ii/Shield/Mk68 /Ugoos/neox5/minix5 (yes they still work lol) mk80 no it doesnt work lol.
#170.1Guest commented09 June 2017, 10:19Editing a commentActually, that link goes to the S905X ROMs. The S905 custom ROMS are here : http://freaktab.com/forum/tv-player-...-roms-tools-bj
Sorry, but I do not quite understand what they tell me. What do I have to do specifically to be able to operate through the Sixasis program, the Chinese ps3 Joystick ?. Sorry to ask so many times but I do not handle my English very well. What is the rom that I should install in my mini m8s so that it works with my joystick through Sixasis ?? please help me . Thank you
Guest
manal_vedder, no matter how many times you ask, I'm not going to be able to help you with this controller because I simply don't have access to the hardware. Did you follow up with Matt_E?
Hi!
First of all, thank you Guest for your great work!
I've installed TvStock on my mini mx3 box, and for some reason my ethernet isn't working, only wifi...
Used the same cable connected to my pc (which certainly working), and still nothing.
The ethernet worked on the stock firmware.
How can i solve this issue?Last edited by AloNs; 20 June 2017, 17:07.
Guest
Originally posted by AloNs View PostI've installed TvStock on my mini mx3 box, and for some reason my ethernet isn't working, only wifi...
Originally posted by Magendanz View PostYeah, I'm seeing the same problem on mine. I tried pulling over a few missing kernel modules from the MX3 stock ROM, but that didn't fix it. I'll continue to investigate, but the old Lollipop builds aren't getting a whole lot of bandwidth at this point.
There are currently 1548 users online. 0 members and 1548 guests.
