[ROM] Mini M8S / MX3 Nano and TVStock (Android TV) Nexus ROMs
Guest
Unfortunately, with wireless drivers it's not as simple as just replacing a kernel module (.ko) file. There are typically entries in the init.rc that need to be changed, and that lives in the ramdisk that's contained in the boot partition with the kernel. You can try reverting to your original boot.img and swapping out the .ko file in /system/lib, but that may break other things.
Guest
There are step-by-step instructions in the link for the flash tools in the original post.- Flash burn package with Amlogic USB Burning Tool v2.0.8 or BootcardMaker v2.0.0.2
Originally posted by Magendanz View PostThere are step-by-step instructions in the link for the flash tools in the original post.- Flash burn package with Amlogic USB Burning Tool v2.0.8 or BootcardMaker v2.0.0.2
Best Regards.
Hi, sorry for my english, and if the reply already published.
Is it possible to flash ugoos firefly like on the GT1 to have cast possibilities ? Thanks.
Hello Guest , I've installed your ROM into my tv box (MiniMX Version 1) and I've fixed wifi connection since its wifi chip is ap6330 (I have to fix bluetooth, so when I'll finish I can give it to you so you can make an update or post the zip here). I've installed the Android TV version but I have a doubt, why I can't find on the Google Play Store some games that I was able to found with the stock ROM? Can I install/upgrade opengapps.org apps flashing them? I've flashed Android TV version thinking I could had been able to download games like Golden Axe (with the stock ROM it wasn't visible on the store) but now I can't see it either, why don't you change the "fake" name of this version from nexus 10 to nvidia shield? Could it works? Thank you.
Android TV uses the Google Play Store for Android TV (PhoneskyKamikazeCanvas), not the old Google Play Store (Phonesky), and the new store looks only for apps that are compatible with Android TV. You can upgrade some OpenGApps using the TVStock variant, but that package has some issues that require manual fixes.
As for device spoofing, I've given up on that particular exercise because I just don't think it works. You can continue to tweak the build.prop, however, and see if you find something that works better. I've actually just reverted to telling the truth.
I just dropped the MX3 TV Stock version on to my KII Pro and it booted up just fine. I'll need to do copy over files to get the wifi to work - but the ethernet worked fine.
This 424 release doesn't seem to have the Nexus Live Channels USB tuner support built in that the M8SPro+ 825 release has. Is this an update you could procide? I'm looking to test the usb tuner/live channelsfunctions on a 905 chip (KII Pro) vs the 905x (M8S Pro+).
Thanks!
Originally posted by edit4ever! View PostI just dropped the MX3 TV Stock version on to my KII Pro and it booted up just fine. I'll need to do copy over files to get the wifi to work - but the ethernet worked fine.
Thanks!
Hello i just flash my Beelink mini MX III S905 (first version) with the : TVStock Variant: BURN PACKAGE (752MB IMG file)
from this tutorial.
It's work great BUT my original remote control dopesn't work anymore. I must use an other remote with usb receptor.
Any possibility to use my original remote control ?
Hi, my MX3 work fine but at each restart, i need to select Language, After this, it recognize my Google Account, etc. but I need to valid each option, like for the first configuration. Not really WAF...
An Idea ? I tried a TWRP basic format 2x but problem not resolved.
PS : Sorry for approximative english...
There are currently 3373 users online. 0 members and 3373 guests.
