[ROM] Mini M8S / MX3 Nano and TVStock (Android TV) Nexus ROMs
Great ROM, thank you very much!
Is it possible to include ff-memless.ko and xpad.ko modules in the next version? These modules are necessary to load to use the XBOX360 wired USB controller. It works like a charm, but manually loading the kernel modules after every boot is a bit painful
Thank you for your work!
Originally posted by Magendanz View PostSure, just provide a link to the ones that are working for you. I don't have the hardware myself, so I can't really test it.
I've uploaded the two modules here:
https://drive.google.com/file/d/0B00...ew?usp=sharing
Guest
Originally posted by xyrnox View PostI've uploaded the two modules here:
In the interim, could you go into Root Mode in CMFileManager, create a /system/lib/modules directory (if it doesn't already exist), place the two kernel modules in there, then reboot? Let me know if that works.
Even when the modules are in that directory to make my controller work I need to load them after every boot like this:
Code:su cd /system/lib/modules insmod ff-memless.ko insmod xpad.ko
Originally posted by Magendanz View PostYeah, I'm seeing the same problem on mine. I tried pulling over a few missing kernel modules from the MX3 stock ROM, but that didn't fix it. I'll continue to investigate, but the old Lollipop builds aren't getting a whole lot of bandwidth at this point.
Guest
No, I haven't really had a chance to dig into it. The Lollipop builds really aren't getting much bandwidth these days.
Hi.
what do I do wrong ?
Flashed TVStock Variant: BURN PACKAGE (752MB IMG file) worked
flash with TWRP , OTA UPDATE (424MB ZIP file) worked
But no Wifi.
So I tried to flash :
An update for the Qualcomm QCA9377 chipset can be installed from TWRP to restore wireless functionality on those boxes.
The result you can see on the picture... I was not able to flash that with TWRP
Any idea ?
thanks
Mike
You may only view thumbnails in this gallery. This gallery has 1 photos.1 Photo
Guest
Well, it seems that somehow the Lollipop QCA9377 update for p200_2G got overwritten with an older build for Marshmallow and p212. The error you see is the script failing an assertion as it checks to see that it's running on the correct machine and firmware build. Unfortunately, I can't find the source for the p200_2G update on my machine anymore, so I'm going to have to rebuild it from scratch.
BTW, the second flash of the OTA update in TWRP was unnecessary. Flashing the burn package puts the same bits on the box.
Are you running on an Mini MXIII?
Guest
You shouldn't need the Qualcomm QCA9377 update for the Mini M8S. I believe it uses the AMPAK AP6255 chipset, and there should already be drivers for that on the ROM. Can you recheck your WiFi functionality, ensuring you're close to your router? (Some of the antennas on these boxes are pretty lame.)
Hi Guest,
I have successfully installed the TVStock rom on my MINIX NEO U1 although I know this rom is not specifically built for my box but it managed to boot fine and runs so smoooooth, however i don't have any WIFI, sound and bluetooth from the original remote.
Can you please let me know if there is a flashable zip file for these drivers?
If not, would a simple copy and paste of the original MINIX rom drivers to the TVStock rom work? I can navigate around the Android filesystem but I'm not sure where to place the drivers.
Thanks for you help!
There are currently 3237 users online. 0 members and 3237 guests.
