MECOOL M8S Pro + TV Box Amlogic S905X Android 7.1 2/16GB Fast Lan, WiFi 802.11b/g/n
Originally posted by hansdampf View Post
I have SEC 713 and FW 0815.
Do i have a problem???
Mine is fairly stable OOB, sometimes you get the "app stopped responding". One time it needed a power cycle.
After improving the thermal paste it does seem a little faster and stable overall.
If yours is fairly stable too that might be an indication that it could work (notice: might and could...)
Originally posted by 4everAnoob View Post
Mine is the same, and I got lucky - no problem after F/W update so far.
Where is the reset button on m8s pro plus ? Front back left right
Sent from my SM-T560NU using Tapatalk
#711.1Guest commented24 October 2017, 01:38Editing a commentHere (if you've got one): http://freaktab.com/node/660688
Got Heat Problems ?
1. Use a better glue. The std. glue can be applied too thickly and is not the best thermally anyway (my guess)
Arctic Silver Epoxy is the best - Close second is the Aluminium version - Note this is PERMANENT Glue.
I used small bead in the centre and this is spread thinly by pressure. I used a 2.75Kg mass.
+ 2. Use a better Heatsink - a 22x22x10mm fits easily and costs buttons ont Bay
Or + 3. Taller HS adds a bit of an extra Air-Gap
You may only view thumbnails in this gallery. This gallery has 3 photos.3 Photos
4x small JIS Cross Head screws are revealed.
Unscrew with sufficient pressure to stop the screwdriver camming out if not using JIS driver.
Lid pops off, no clips.
E&OE
Originally posted by stlab View PostHey Guys,
I'm completley new.
I've ordered the m8s pro + device from Gearbest.
I've the Version without a Reset switch. I wan't to boot libreelec form SD-Card. How can I do that without switch?
So I received my box from gearb and the firmware it came with was 0815. There is a reset button.
The box hasn't froze up on me but it seems quite buggy. I have a logitech mouse connected to it, and the mouse cursor is restricted to the top left quarter of the screen. After a while, the overlayed settings menu on the right becomes quite sluggish. Youtube (playstore version) came preinstalled, but it is not listed in the app drawer, only the settings app list, so I can't add a shortcut.
Am I safe to update to firmware 0919, which as I understand it is the latest firmware for this box?
When updating it with USB Burning Tool is it similar to the Mini M8S II and that you load the firmware, press start, press and hold the reset button and plug the box in via USB? If so, does it matter which USB port?
Any help would be appreciated.
EDIT: I took the risk and just went ahead and updated the box (I know I should have probably taken it apart to check the emmc etc.) but I lucked out and it flashed no problem.
The box seems snappier so far but I just installed it.
The only issue I have with this firmware is they seemed to have removed the option to show the status bar. Is there anyway to get that back with this firmware?
edit2: Also annoying is the sound sliders are linked to each other. I can't set the media volume to max and other volumes low like I usually do.Last edited by rahzel; 26 October 2017, 21:40.
Originally posted by rahzel View PostSo I received my box from gearb and the firmware it came with was 0815. There is a reset button.
And could someone successfully mirror the phone/tablet to the Mecool M8s Pro+?? I can just share pictures oder videos but not mirror the whole screen.....is there a extra app to for mirroring? i have a Samsung A3 2016 with Marshmallow
There are currently 4341 users online. 0 members and 4341 guests.
