MECOOL M8S Pro + TV Box Amlogic S905X Android 7.1 2/16GB Fast Lan, WiFi 802.11b/g/n
Originally posted by PaJoe View Post
Originally posted by grimmie View Post
I am new at doing this, I used the paper clip method shown in this thread. It took several tries to get to the button as it is hidden and a couple times the paper clip slipped off the button but after a few tries all started working, my unit went directly into upgrading
Link to picture Magendanz posted below;
Just got a new box delivered from BangGood.
My order was made during the super cheap 11th Aniv. Sale but was delayed shipping - Maybe the bad batch was withdrawn !?
The new box is build Date Code - BB-ROC170825PS
eMMC is Kingston
RAM is 4x matched code (Not just marked D/X)
There is NO RESET Button !!
FW - V0619 (20170914.183646 V0619)
UPDATE:
Bad UK Power Supply - Causes Issues with RF Transmission.
BAD has Round Coax power lead - Good has Twin-Wire lead (also smaller bulge!)
Has anyone posted the OTA FW on GeekBuying Blog (in this thread) ? - if so apologies for reposting
http://blog.geekbuying.com/2017/09/m...date-20170927/
EDIT: Of course they did ! Page 37 - and there is an IMG link too
http://freaktab.com/forum/tv-player-...166#post674166Last edited by P.X; 04 October 2017, 12:02.
I flashed that OEM tablet Android OS yesterday using its own recovery.img on a good Samsung 5.0 eMMC M8S Pro+ box.
If I did not get my .zip's mixed up that v0619 .zip update contains an Android TV Google Playstore where you can install all the Android TV Apps and have them run properly on the tablet Android OS.
Originally posted by wrxtasy View PostI flashed that OEM tablet Android OS yesterday using its own recovery.img on a good Samsung 5.0 eMMC M8S Pro+ box.
If I did not get my .zip's mixed up that v0619 .zip update contains an Android TV Google Playstore where you can install all the Android TV Apps and have them run properly on the tablet Android OS.MK818B, T428, ATV 1220, CS918S, TV01, S89H, R89, ADT-1, MK808B Plus, MINIX X8-H Plus, Tronsmart Orion R68
I brought it at the cheap price just to use with LE, all attempts to boot to an LE card have failed though. The box fails to boot from cold with LE card in it. The same card boots to LE fine in other boxes through adb reboot update or similar. I'm guessing from your last post above I need to short reset pads just to get LE running, is this correct? Please can you point out the pads for me before I take the thing apart? I see the red box on your pic of the front right of the board, but not sure which pads to short from your later post.
Also you mention the UK supply has RF Transmission problems. I have the same supply, although BG supplied it with a UK plug adapter as well for some reason. Can you elaborate on what the issues are with the UK supply we have? It's near my wifi router, but doesn't seem to cause any noticeable RF issues. I'm using wired rather than wifi from the box FWIW.
Originally posted by wrxtasy View PostAll you do is reboot Android.
After the very first LibreELEC install/bootup, where you have to use the Reset button.
Any subsequent reboots or power ups will boot straight into LibreELEC with no user intervention necessary.
This following is a really good LibreELEC Mod. to do to speed up LibreELEC Kodi quite noticeably for day to day use.
[HOWTO] Boot from SD card, use internal memory for data (click)
There are currently 1455 users online. 2 members and 1453 guests.
