MECOOL M8S Pro + TV Box Amlogic S905X Android 7.1 2/16GB Fast Lan, WiFi 802.11b/g/n
Originally posted by acefr View Post
The box has a crappy dirt cheap wifi module, so I am not surprised. Another reason is your 2.4GHz wifi bands are congested at your home, so there are lots of interference. One way to test is using your laptop with a LAN port, enable ICS (Internet sharing), and plug a LAN cable to your laptop and the box, and see if the internet stays connected at your box. If so, you will need a wifi bridge.
I've finally decided to just buy a powerline adapter.Last edited by rahzel; 02 November 2017, 11:56.
Originally posted by rahzel View PostThe location of the box is not far from the router. I don't understand why so many of these boxes have such poor wifi chips. I've tested dozens of boxes and it seems like almost half of them are poor or next to useless.
Could just be the wi-fi chip though ?
Hi there,
Anyone uses harmony logitech ( model 555 ) to control the Mecool ?!?!? If so, which one did you pick when you programe the remote?
Does anyone uses this skin for kodi "Skin MOD - MOD AEON MQ7 KRYPTON" ???
In this skin I don´t find the option to reboot for the native OS of the Mecool ... Does anyone knows if it´s possible and how !?!?!? I really need the double boot because I use some apps in the Andriod Tv of the box ...
I think you are talking about Dual Boot LibreELEC / Android yes ?
If so follow this DIY:
https://forum.libreelec.tv/thread/58...8260#post68260
Gonna write this in case it helps someone in the same situation as me.
I got a box with the faulty eMMC and 20170829 firmware. After trying to update to a newer OEM version, I bricked it. USB burning tool always fails at 98%. I thought at least I would be able to use it for LibreElec off an SD card but the light stayed red+blue and didn't turn on.
After trying a hundred different times and many different things, I was able to get it to a point where it reliably loads LibreElec from an SD card and so far it seems to work perfectly. Here's what I did:
- Took the M8S_PRO+-20170829.121614.V0321.img that Magendanz posted
- Opened it with Amlogic Customization Tool
- Opened C:\Program Files (x86)\Amlogic\CustomizationTool\tmp\level2\system in Windows Explorer and deleted everything in that folder.
- Packed it with Amlogic Customization Tool, resulting in a ~67MB img file
- Flashed that img file with USB Burning Tool. Tried all the different "Erase flash" options. "Erase bootloader" checked.
Sometimes the flashing process crapped out halfway, sometimes it finished successfully. I got many successful flashes but LE still didn't load fully. I'm not sure if I did something different this last time or if it was pure luck, but now it loads LE successfully all the time.
For some reason, LE 8.2-8.2.0.1 doesn't load. It works fine with an older 8.0.2a and with a newer 9.x from http://kodi.adamg.co.uk/libreelec/releases/ (I used 1.0.4.1)
I don't want to try flashing anything again for fear of bricking it again. If you are in the same boat with a bricked M8S Pro+ and want to try loading LE on it, let me know and I'll upload the stripped img file for you to try.
UPDATE: Shortly after posting this, I decided to take the plunge and try flashing the full M8S_PRO+-20170829.121614.V0321.img with USB Burning Tool and lo and behold, it flashed successfully! Everything is back to how it was when I first received it, and so far there haven't been any crashes. So it appears there's hope after all for boxes with bad eMMC, even if they were shipped with 20170829 firmware. As a side note, I did lose Widevine L1, it's now L3.
Cheers!Last edited by polpus; 05 November 2017, 23:39.
Originally posted by wrxtasy View PostI think you are talking about Dual Boot LibreELEC / Android yes ?
I´ll give it a look ...
Thanks a lot !!!
Originally posted by rahzel View PostThe location of the box is not far from the router. I don't understand why so many of these boxes have such poor wifi chips. I've tested dozens of boxes and it seems like almost half of them are poor or next to useless. (edit: not the Mecool, just android boxes from GB in general).
There are currently 2419 users online. 1 members and 2418 guests.
