MECOOL M8S Pro + TV Box Amlogic S905X Android 7.1 2/16GB Fast Lan, WiFi 802.11b/g/n
    BTW, I was noticing in the u-boot usage doc that the write command automatically skips bad blocks. That would explain what we're seeing with those partial firmware writes on the affected boxes. If the same "bad blocks" are always skipped, they might retain their original contents from the factory firmware. Then only reflashing the original firmware would restore their integrity.
    Code:
    gxm_q20x u-boot Usage:
    store store init flag
    store read name addr off|partition size
            read 'size' bytes starting at offset 'off'
            to/from memory address 'addr', skipping bad blocks.
    store write name addr off|partition size
            write 'size' bytes starting at offset 'off'
    store rom_write add off size.
            write uboot to the boot device
    store erase boot/data:
            erase the area which is uboot or data
    store erase partition <partition_name>:
            erase the area which partition in u-boot
    store erase dtb
    store erase key
    store disprotect key
    store rom_protect on/off
    store scrub off|partition size
            scrub the area from offset and size
    store dtb iread/read/write addr <size>
            read/write dtb, size is optional
    store key read/write addr <size>
            read/write key, size is optional
    store mbr addr
            update mbr/partition table by dtb
      Originally posted by hansdampf View Post
      I had exactly the same problems with my M8s Pro+(Gearbest, FW:0815, sec 713)....it might be possible for u to look witch emmc u have inside? there is a app in the play store called "eMMC" to look for.... i'm still afraid to update to FW:0919 and to brick it.
      And could someone successfully mirror the phone/tablet to the Mecool M8s Pro+?? I can just share pictures oder videos but not mirror the whole screen .....is there a extra app to for mirroring? i have a Samsung A3 2016 with Marshmallow
      The app didn't give me any relevant info from what I can see. But thanks for the tip.
      Like I said, I went ahead and updated my box and thankfully it went smooth. However the firmware itself was... meh. It felt smoother but they removed the status/navigation bar option in the display settings. The volume controls are linked. And play store was the Android TV version and the regular version downloaded from apkmirror didn't work.
      I decided to flash to magendanz nexus rom and it runs just as smooth, if not smoother, and magendanz's rom has the status/nav bar option still there. So far I'm fairly happy with my box now.
      Big thanks to megendanz for his work.
        Could someone successfully mirror the phone/tablet to the Mecool M8s Pro+?? I can just share pictures oder videos but not mirror the whole screen .....is there a extra app to for mirroring? i have a Samsung A3 2016 with Marshmallow
        @rahzel
        what is the chip the eMMC app mentions? can you tell us? in my case it's KLMAG1JENB what means the bad SEC713
          Originally posted by dstojic View Post
          With SD card in slot in Terminal app you should type reboot update and then box reboot Libreelec. If you want reboot in Android you should pick Reboot from internal from shutdown menu on Libreelec.
          Thx for the answer.
          I've tried but it only boot into the Adroid Recovery not from the SD-Card Click image for larger version
            Originally posted by stlab View Post
            Thx for the answer.
            Do you have properly SD card with Libreelec on it? When you do "reboot update" Libreelec from SD Card must boot up.
              I just check everything.
              It was my fault GRRRR. I used a wrong image "LibreELEC-S905.arm-8.2-8.1.10-C2.img" insted of "LibreELEC-S905.arm-8.2-8.1.10.img.gz".
              now it works fine. Thx for your support
                @rahzel
                Under chip type it says AJNB4R...is that what you're looking for?
                edit: after googling this code, it seems to be a Samsung chip. Aren't the Samsung chips suspected to be the faulty batch? Or is it only certain Samsung chips?
                My box runs fairly well running magendanz Nexus rom. No lockups yet. My only issue is the WiFi seems to drop for a second the odd time, but I suspect that's a HW issue.
                But yeah, I was able to flash to magendanz rom, as well as GB's 0919 firmware using USB Burning Tool without any issues.
                  Sorry to say, but i had the same code (now i remember) and it's a SEC713 witch is in the faulty area according to freaktab....but really strange that no brick happened....there was also a other guy with Fw0815 and SEC713 who had no problems flashing the box maybe this combination is risk free
                  Guest knows more i'm sure
                  • Guest's Avatar
                    Guest commented
                    Editing a comment
                    Actually, I have three boxes and none are from the affected batches, so I'm guessing like the rest of you.
                  I can't find the WIFI Settings in LibreELEC. Click image for larger version
                  The device-tree is from:
                  is it not supported or is there a way to get it work?
                    Interesting. Not to point the finger or anything, but perhaps something went wrong with the flash procedure? USB cable or something? Admittedly I haven't been following this that closely so I don't know how many people have bricked their boxes.
                    I use a USB 3.0 cable and a USB 3.0 port to flash my boxes and run USB Burning Tool 2.0.8.
                    I flashed my box the same way I did my M8S Mini II: load firmware, press start, plug one end of USB cable into PC, press and hold the reset button and plug the USB cable into the box. I normally release the reset button once all of the windows notification beeps stop.
                    I've flashed the firmware 3 times using the above method with no issues; once to 0919, then back to 0815 because I wasn't happy with 0919, then finally to magendanz rom.
                      I haven't flashed yet. Just made a factory reset. It seems to be better than before now. Bought this box because of the roms but now looks like risky
                        I updated the firmware (NHG47L 20170919.150557.V0619) on my box by zip file using a usb stick. I have never flashed a box before by the method described on the op. Is there any difference between the two methods? Thanks
                          From what I understand, LibreELEC does not support this wifi module, so you need to provide a LAN connection. Not sure if this info is still up to date.
                            acefr is correct, no Linux/LibreELEC drivers for the dirt cheap WiFi Chip they put in the M8S Pro+
                            Even the WiFi Chip manufacturer will not release the driver source code to LE developers, enquiries have already been made.
                            Its why I would recommend actually buying the MECOOL M8S Pro L - that has working Bluetooth and AC WIFi in both Android and LibreELEC and has no risk of receiving a box with dodgy eMMC Samsung flash storage (yet)
                            Guest has also made a similar recommendation.
                              Does the L version support Netflix HD?
                              Enviado desde mi Moto G (4) mediante Tapatalk
