MECOOL M8S Pro + TV Box Amlogic S905X Android 7.1 2/16GB Fast Lan, WiFi 802.11b/g/n
Originally posted by scooter2014 View PostDid you even look at post 587? Bricked Kingston.... Shall i keep posting more kingston ones to prove it not just one batch of samsung emmc ?
P.X found the same info in that post as I did.
If MECOOL box users have unreliable and frozen M8S Pro+ boxes simply from Flashing OTA officially distributed Firmware then they have one of the dud/faulty boxes and should seek an immediate refund from the Seller and not even try and self repair the device.
Hi all, i bought a MS8 Pro +, but it hasnt arrived yet. I would like to know which kernel version does the box has, cause i would like to use a USB DVB-T tunner, this one by MyGICA: https://es.aliexpress.com/store/prod...883597971.html
I know it is meant for PC, but in the description it says that works with Android 4.1 and above. I am not sure if it does, cause i have read this new model is not supported by the linux pc kernel yet: https://lurchi.wordpress.com/2017/01...t230c-hacking/
May be for Android it will be different.
Has anyone tried that Mygica USB TV Tunner ?
Hi all.
I installed the Nova launcher with the stock ROM but even if I set it as the default launcher, it initially launches the Mecool stock launcher every time it boots up. Then I have to press the home button to go to Nova Launcher (w/c is now the new default).
Is it safe to just disable the mecool launcher in Titanium Backup (or by deleting the app in the system folder)? Has anyone tried this?
I can always try this but my box is included in the "bad" chip batch SEC 713 and it will be harder to recover my box in case it will not normally boot if somethings went wrong.
Ya even changing wallpaper a bit of pain on this one. Maybe they fix and release ota for that and launcher issues. Seems that on mine as well.... Would be nice to select and customize a bit... Seem same in other firmware for 7 so hopefully they fix. For such a cheap box kinda surprise even it get one ota lol....Many devices now mk902ii/Shield/Mk68 /Ugoos/neox5/minix5 (yes they still work lol) mk80 no it doesnt work lol.
Ok had alot of studders some freezes. So opened box. Heat sink looked ok paste was poor holding it. Removed it Thremal adhesive and clamped. Installed large plate from another device. Temps reduced now running smooth no studder or freezes so those having them might want to redo the heat sink attachment. That in it self will reduce heat transfer to lower board.
Originally posted by Rubytux View PostHi all, i bought a MS8 Pro +, but it hasnt arrived yet. I would like to know which kernel version does the box has, cause i would like to use a USB DVB-T tunner, this one by MyGICA: https://es.aliexpress.com/store/prod...883597971.html
Please update your progress.
Originally posted by scooter2014 View PostOk had alot of studders some freezes. So opened box. Heat sink looked ok paste was poor holding it. Removed it Thremal adhesive and clamped. Installed large plate from another device. Temps reduced now running smooth no studder or freezes so those having them might want to redo the heat sink attachment. That in it self will reduce heat transfer to lower board.
Maybe I will try to put the heat sink like the one you did later on since I do not have a heat sink and thermal glue at the moment. For some energy saving? I guess?
Btw, is your box in the lucky or unlucky "faulty" batch?
I have some experience with that TV-stick. I have set up a Raspberry Pi 2, running LibreElec with Mygica T230c. My tech invalid father has been very pleased with it. Mygica T230c works great with LibreElec media build branch. I am not sure if the images made by kszaq for the S905(X) are using the media build branch of LibreElec. You should really ask him, but he is on holiday atm. and won't probably be back at least in a week. There may be other englihtede persons in the LibreElec forum that can answer this question. What comes to android and DVB-tuner support, to my understanding it is close to non-existent atm. Please correct me if I am wrong.
I am trying to get my K1-T2 (S805) box with DVB-tuner to work in LibreElec, if I can't, I am going to use my Mecool M8S Pro+ with Mygica T230c to replace the Raspberry Pi2 in my fathers setup as it is needed elsewhere. If I have to go down that route, and I am successful, I can make some kind of instructions/tutorial how to do it, but it's going to be, in the earlies, end of this week, when I am going to visit my father.
Also, if I have to use the Mecool M8S Pro+ in my fathers setup, I am sadly unable to provide any more serial logs and do testing to help solve this issue with the effected batch.
Originally posted by Rubytux View PostHi all, i bought a MS8 Pro +, but it hasnt arrived yet. I would like to know which kernel version does the box has, cause i would like to use a USB DVB-T tunner, this one by MyGICA: "Link removed, because my posts won't go trough otherwise!"
I know it is meant for PC, but in the description it says that works with Android 4.1 and above. I am not sure if it does, cause i have read this new model is not supported by the linux pc kernel yet: "Link removed, because my posts won't go trough otherwise!"
I have some experience with that TV-stick. I have set up a Raspberry Pi 2, running LibreElec with Mygica T230c. My tech invalid father has been very pleased with it. Mygica T230c works great with LibreElec media build branch. I am not sure if the images made by kszaq for the S905(X) are using the media build branch of LibreElec. You should really ask him, but he is on holiday atm. and won't probably be back at least in a week. There may be other enlighten persons in the LibreElec forum that can answer this question. What comes to Android DVB-tuner support, to my understanding, it is close to non-existent atm. Please correct me if I am wrong.
Also, if I have to use the Mecool M8S Pro+ in my fathers setup, I am sadly unable to provide anymore serial logs and do testing to help solve this issue with the effected batch. Naturally I can test the Mygica, even if I get the K1-T2 working.
I bought my Mecool from Gearbest on 12th september, shipped 23th sep.
eMMC App says: AJNB4R (it's a Samsung according to google)
BuildNO: NMF26Q 20170815.182813.V0321
I have regular freezings, crashes and every time "google play services stopped working" massage
Do i have the bad chip/batch??
What can i do?
If your box is running the stock firmware and you have not done any modifications to it. I would suggest you first contact Gearbest support for advice/replacement/refund. They may take couple of days to reply. If you can't get hold of them, then you can ask politely in the Grearbest support thread here.
If you have flashed your box you should first try to flash back the stock firmware and see if it helps.
If you have made some modifications or void your warranty in some other way. You could try to solder serial header to your box and check the serial debug output. It could also be the heat sink is not seated on properly as it appeared to be case in scooter2014 box, few post above. If you have an infrared thermometer, it should be relatively easy to open the box up and measure temperatures of motherboard, underneath the CPU, and the heat sink. If there is huge difference, it would suggest your heat sink is not in good contact with your CPU.
Tieri no i haven't done anything yet, just downloaded 3-4 apps like Opera but it's freezing. A lot of people tell me to open the device to look after the chip, but i'm affraid that would void my warrenty....but i think is not necessary because all of the guys with the same BuildNo, which bought from Gearbest hast the faulty eMMC SEC713
(and the info from a emmc app tells me also that it is a Samsung chip (AJNB4R)
SEC 5.1 eMMC Flash Issue - Clarification
This issue is very specific :
It is
1. Box freezes - Sometimes with Audio "Buzz", screen freezes randomly in any app.
2. Box can freeze when only the Launcher is active from start, just by moving about the launcher (L, R, UP, DOWN)
3. Box can crash and will not re-boot with Remote - Requires a Power Cycle (OFF-ON)
3. Box has SEC 5.1 chip KLMAG1JENB - B041 (Probably not any other eMMC - No Kingston or Samsung 5.0 reported with this specific issue to my knowledge)
4. Update using OEM Update App and OEM provided .zip Firmware causes catastrophic boot failure to a Screen Freeze/+Buzz within mere seconds of all Power On actions post update.
This issue is NOT
1. Overheating
2. Stuttering playback
3. Messages saying X App has Stopped.
4. Crashes to Standby that allow a simple restart with the Remote Control Power Button
5. Boxes Bricked or Borked by incorrect flashing (Cables, settings, inappropriate FW, etc.)
6. App X not performing as it does on a different box, etc.
7. etc.
Only some chips from specific SEC Batch Codes seem to be affected - SEC 701 to 713.
The Batch Number does not indicate a certainty of having the issue.
There may also be other SEC numbers affected.
The original installed at factory FW 20170829, and FW 20170815 have been reported present - Again does not indicate certainty of issue (+some people do not note the original FW loaded on their box)
The original installed at factory FW 20170829 has never been released as a .zip or .img by the OEM.
Restoring to the originally installed factory FW may restore the initial state of the box (this will probably still have any freezing issue, but will at least load past the First Use app screen).
HTH
E&OE
Last edited by scooter2014; 17 October 2017, 01:02.Many devices now mk902ii/Shield/Mk68 /Ugoos/neox5/minix5 (yes they still work lol) mk80 no it doesnt work lol.
Perfect. Exact chipset my three boxes here.. And all now running fine after the mod to the cpu
Agree manufacturer input would be good.
Agree heat a big (different) issue. I have one box that needs some attention as it runs at 85C/185F at times, and that is asking for trouble.
Decent Arctic Silver epoxy on way ....
plus may have to do mod like you also .........
There are currently 3727 users online. 1 members and 3726 guests.
