From your experience can I hope for a refund from gb?because it was freezing since I opened it....
MECOOL M8S Pro + TV Box Amlogic S905X Android 7.1 2/16GB Fast Lan, WiFi 802.11b/g/n
Originally posted by satyros View Post
Thx for the quick response?
Originally posted by Magendanz View PostLooks like trebor found an OTA update for 20170919.150557.V6019 posted on the GeekBuying blog: https://mega.nz/#F!uZNjnR6Z!QAhnJ_q05q3kk2CGTmRIbQ
I'll convert this to a burn package later tonight.
UPDATE: Here's the .img file: http://freaktab.org/1a39f6c99cfc7a8a
I went to this page: http://blog.geekbuying.com/2017/09/m...date-20170919/
And it has a download link, but i think that IMG is for the 0815 Firmware, it weights 1.3 GB: http://geekbuying.mediafire.com/file...2813.V0321.img
Now watching this link: http://freaktab.org/1a39f6c99cfc7a8a it comes with this file: M8S_PRO+-20170919.150557.V06 19.img it weights 1.51GB, that's the 0919 OEM Firmware. Or is it your Android TV 7.1 Firmware ?
Here in MEGA there is another OTA Firmware: https://mega.nz/#F!uZNjnR6Z!QAhnJ_q05q3kk2CGTmRIbQ It is named M8S_PRO+-ota-20170919.150557.V0619.zip, it weights 987.4 MB, i suppose it is the same OEM 0919 firmware, just as an OTA download. That's why it weights less MB than the files posted before.
Any 0919 Firmware would be OK to flash, right ? I just want to know if both link are for OEM firmware of if any of those link are for the Android TV 7.1 firmware
#545.1Guest commented28 September 2017, 20:43Editing a commentYes, the OTA updates are going to be smaller, since they're compressed as .zip files. I'd recommend you install the latest official OTA update from the OEM, then see how you like it. The burn package (.img file) is really for those wanting to do a clean install, just like at the factory.
If you find you'd prefer more of a Nexus Player experience, then you could install my latest Nexus TVStock custom ROMs. If you just want Kodi, you could install LE.
But if you end up with one of the bad batch with NAND problems, you're basically screwed no matter what firmware you install. Even installing LE on an SD card will exhibit the problems, just less frequently because you're not running off eMMC.
It depends what fw your box gets shipped out as. If it is 20170829 then all people (me inclusive) has had the box crashing after loading the firmware from either the 20170815 or 20170919 firmware on the GB firmware blog. I recommend you not to use either of this firmware.
But you'd want to head to LE to get this box to run that OS from a micro SD Card (you need to invest in a $12 Level 10 SDHC) and have a very smooth kodi.
oops sorry seems like it does tried to post using my phone but didn't work earlier kept on saying unapproved. So let me fill you in on whats happened so far as I really need your help...
I bought a mecool m8s pro+ 2/16gb box with widevine L1 and us plug version which came through yesterday from Bangood which i ordered early september. I believe the firmware preinstalled was dated august but cannot recall the date, however I then tried using the burning tool to use the tvstock nexus rom Guest created to get the android tv experience. In order to get the burning to recognize the device I had to click hold the button using a pin behind the front grill, then plug in the male usb. The box has a pinhole underneath but there is no button. Once it was recognized i went ahead and imported the image and clicked start.... having ticked normal erase and bootloader. Initially after few % it failed.. something about partition. Then tried again it gave another reason. Then tried again with another mangendanz rom dated earlier and again it failed. So i kept trying and eventually I didn't have to hold the button anymore, the burning tool recognized the box straight away. However now it only goes to 4% and the reason shown is unknown. Also the box is only showing red light before it used to show red and blue when connected to the burning tool or when I used to switch it on.
I really need you help to seek out any use out of the box as now i believe its bricked and i cannot restore it to factory either. I only used the box for 30mins before trying to install the atv rom to a fully unusable box. If you require further details let me know.
Many Thanks
Rez
The link below shows someone else who have had this issue...but it was dated Jan 2017.
I have TX3 Pro android box and it's bricked. I want to restore the firmware with usb burning tool but it always getting error when I start it. It stuck on 4% at
Guest
Originally posted by P.X View PostHardware (component) change between my first and second boxes ...
BB-ROC170703PS - July Version : Chips marked ..
EMMC : SAMSUNG 646 . KLMAG2WEPD-B031 . S4ZN1010 (EOL 3bit MLC - Data Sheet)
Memory Chips (?) : C71V217400
BB-ROC170811PS - August Version : Chips marked ..
EMMC : SEC 701 . KLMAG1JENB . B041 . S558Z034 (Current 2bit MLC - Data Sheet)
Memory Chips (?) : D / G
First post here. I have followed this thread for a while as a guest, but decided to register to give you some information from a German forum that might give some additional information. Don't know if they can help, but might not harm. Quite some people ordered the Mecool MS8 Pro+ on 10. Sept from Gearbest and BG (almost same flash sale price) and now they are coming in while other orders are still not shipped yet. I received my Mecool from GB last week and it also has the 20170829.121614.V0321 FW. I didn't notice any freezing yet. No OTA or Custom ROM update. We didn't received any freezing problems in this German forum until now. Here is the thread, if you like reading German: https://www.mydealz.de/deals/mecool-...mment-14961854
Pics from German buyer of BG box. It has a SEC 713 chip. He soldered an USB to UART cabel on the MB.
Last but not least: a big shot to Guest (sounds German) for the great work, I am so tempted to flash your ATV ROM, but have to figure out this problem first
PS: direct translation: stomache dancer. love U to dance. cheers, mateYou may only view thumbnails in this gallery. This gallery has 4 photos.4 PhotosLast edited by Hearsay; 29 September 2017, 10:22.
Originally posted by trebor View PostI will speculate only
Who ever was flashing the Boxes at the factory, not knowing the eMMC has been updated to 5.1 as 5 is EOL.
Flashed the old ones then new ones as they piled up so continue
Yep she'll be right mate
Purely speculation only
There are currently 1952 users online. 0 members and 1952 guests.
