NEW - iMito QX-1 - 4.2.2 - Finless ROM 1.5
    How to install this rom coz I just got my imito qx1 and it crashes when I launch internet browser. I have stock firmware with no updates. Do I need to have the device plugged into hdmi when doingthe update or flashing custom rom?
      Download the Rom, and read the readme file inside the zip for instructions.
        Me stupid. I thought it is like android on phones. Download zip and flash it. He he. THX all is good now. Flash successful
          How to flash the iMito QX1
          Hi:
          How do I flash the iMito QX1 i am using Windows 8 Pro 64 Bit. I try flash it by using a pin and OTG port and i does work and the computer says it can't recognized the device, I also try install the drivers for it but not luck.
          I also try the usbmass and debugging and when I use a pin to click the reset button i don't hear or feel any clicking.
          Can you please help.
            Originally posted by Moyenda2k14 View Post
            Hi:
            The flash tool can't recognize it BECAUSE you didn't get the Windows drivers installed... so that is where you start.
            Look in the comments area of this blog for a link to the Win8 drivers http://blog.geekbuying.com/index.php.../#.Uva8R_ldVqR
            I can't help with the reset button issue you are having... I had no such problem and it is also required so your device is in the proper mode to flash. I will say it is a micro switch and I feel the click but don't really hear it.
              I try the link you gave me already doesn't work. Are there any videos or something ?
              Is there another way to get to flash mode without the pin.
                  See if these instructions help with the drivers http://blog.geekbuying.com/index.php.../#.UvbKH_ldVqR
                  The switch that you push with a pin... is how you get into the proper mode to flash. You may want to get someone there to help you with it just to make certain you didn't misunderstand something.
                    When I try to install the drivers manual it says unable to.
                      If you use the Finless Bob Flash Tool you don't need to use the pin. Is there any other ways to install the drivers for the iMito QX1.
                        Disable Driver Signature varification perhaps.... http://www.howtogeek.com/167723/how-...igned-drivers/
                        If that doesn't do it... just a pointer... Don't be so brief in your description of what you are doing and give the exact error messages... what you've given up till now isn't cutting it. Technical issues require technical details to overcome... don't expect someone else to psychically figure it out for you, it doesn't work that way in most cases.
                          Ok I send you pictures
                            Ok
                              Ok
                              I try Disable Driver Signature varification perhaps earlier
                                Feel free to use the forum search function for other possible ideas for your Windows 8 issues.
                                Others have had issues and ended up using a different version of Windows ( and drivers ) to get around it instead of actually getting them installed properly on their Win8/Win8.1
