NEW - iMito QX-1 - 4.2.2 - Finless ROM 1.5
Re: NEW - iMito QX-1 - 4.2.2 - Finless ROM 1.5
Originally posted by jy_p View PostHi, thanks for replying, I had that problem with the stock ROM, so I flashed it with this 1.5 but I still have the same glitches problem. I even tried lowering the clock but still no luck... I'm out of ideas.
Look at too the hdmi cable, test the stick directly connected to the tv if you can.
Originally posted by leolas View PostSo much Hot can be the cause, because you are using a stock speed kernel, right?
leolas
http://www.mediafire.com/folder/2w8w...kr/sharedThese are 3 videos that have made that shows the problems I am having.I tried:Stock ROM, STD Clock
Finnless 1.5 720 STD clock kernel (no overclock)
Finnless 1.5 720 STD clock kernel with lower clock setting (no overclock) I always get the same problem.The stick is connected straight into the DVI input of the TV.Evertything was fine with my Imito MX2, so the problem is not the TV.Thanks again for helping.
Try to attach the stick directly to the screen without the hdmi extension.REMEMBER, YOUR FEEDBACK IS VERY IMPORTANT TO US.My devices:
I am not sure the BT issues can be fully fixed. At least not for BT signal range. Seems when wifi is on it stunts the signal range of BT. Imito has not fixed it in their own ROMs so it makes me think hardware for some of the issues which is why we are now seeing a QX-2.
Originally posted by Finless View PostI am not sure the BT issues can be fully fixed. At least not for BT signal range. Seems when wifi is on it stunts the signal range of BT. Imito has not fixed it in their own ROMs so it makes me think hardware for some of the issues which is why we are now seeing a QX-2.
Bob)... When streaming music via bluetooth to my bluetooth reciever, internet drops down to 1 mbit/s...
Two ways to work around it:
Disable wifi and plug in a cable
Set the router to wireless G... for some reason this works on the Ipad, so it just might work for the stick...
hope this helps...
cheersImito QX1
leolasROM-qx1-1.5 (30-10-2013)
kernel_leolas_qx1_1080p_vsfsam_cpu1800_ddr720_gpu7 98_qx1-wifi
XBMC XAF build (12.1)
Tronsmart TS-01 airmouse
Powered USB hub
Originally posted by beckett View PostHi
I am now in a boot loop with Finless v1.5. Please advise on how to fix. ThanksImito QX1
Powered USB hub
Boot loop
I used the defaults for Imito_QX1_4.2.2_Finless_15:
No Overclock 720 kernel
boot720.img
2gig APP space
I Erase NAND (IDB) and it counted to 2048 and it said erase success
I waited 5 minutes after it flashed.
Sometimes, it will go to the desktop then reboot, most of the time it just keeps rebooting at the Finless screen. Thanks for your help.
VPN Connection problems
Hi there
Firstly a massive thanks for all the work - I'm really enjoying the device thanks to your efforts.
I have an issue, when I connect to wifi via a VPN the connection regularly stops. The Imito works fine, except that I can't connect to the internet. If I turn the VPN off and on again, it solves the issue. Sometimes it stops working after 5 minutes, sometimes 20 - totally random as far as I can see.
boot720.img
2gig APP space
Any advice that anyone can give me would be much appreciated.
Thanks again
Whenever i connect or disconnect my logitech wireless (keyboard, mouse) combo while qx1 is running i get this error.and then applications stop working from running or installing, updating. Figured out this probably cause after sevaral attempts of flashing different roms. With leolas and finless rom it gave problem while with stock rom it didnt.
Hi All!
Flashed the firmware iMito QX-1 - 4.2.2 - Finless ROM 1.5. All is well, but ran into some problems.
1. After rebooting the device is lost wi-fi, does not turn the module itself, helps only a full power off.
2. I connected the remote Mele F10 with a headset, the default sound is on F10, it is configured output over HDMI, everything starts to work fine, but after a reboot, shutdown and so on. all the flies, and the sound comes through again F10.
Can you help fix this?
Sorry for my english.
Thank you.
Thank you.
2. Lets see if Bob can fix it, sorry but I cant help on this.REMEMBER, YOUR FEEDBACK IS VERY IMPORTANT TO US.My devices:
There are currently 7877 users online. 1 members and 7876 guests.
