MECOOL KM8 Google Certified Android TV Box with Voice Remote - S905X Android 8.0 2/16GB VP9 HDR10 Dolby Audio YT 4K
Hmmmm. I?m able to boot, i bought km8 a week a go from aliexpress, it is android 9 certified, i needed to push reset switch and power button switch in the same time, the power supply pushed to box and i booted what ever i like form sdcard, but there is no wifi, i choose dtd from 29. Page. Wifi is sooo poor in android 9!!! Is there a link to android 8 for this box? i have ap6236 wifi chip
Here are KM8_Android_8 version: "http://freaktab.org/a40152295e4f21e5" or here "https://mega.nz/#F!NQxVURDB!__BT-yJmLOSFAuqsqsb-iA"
It's the same version my KM8 came with, but my box has AP6212 WiFi chip which works OK on Android 8. I never updated to Android 9...
It's installed via USB stick...
Originally posted by shuky View PostHmmmm. I?m able to boot, i bought km8 a week a go from aliexpress, it is android 9 certified, i needed to push reset switch and power button switch in the same time, the power supply pushed to box and i booted what ever i like form sdcard, but there is no wifi, i choose dtd from 29. Page. Wifi is sooo poor in android 9!!! Is there a link to android 8 for this box? i have ap6236 wifi chip
Originally posted by tagi123 View Post
so you if you want to boot from SD card you need to do it manually (by pushing reset and front button)? After next reboot, box will boot into nand/Android or SD?
How can I find which Wi-Fi chip it's got?
Originally posted by The Brain View PostI don't know if mine is AP6236 or AP6212, only that it's just as bad in Android 9 as it was in Android 8.
Originally posted by tagi123 View PostAbove posts that coreelec boot with android 9 is working, isn't true. I have tested it and there is no way to boot from SD or USB when running Android 9.
After downgrade possible again.
1. Try manualy update aml_autoscript.zip - google how to do that
2. Use android terminal run command "reboot update"
Originally posted by ad_lopta View Post
Just push power button until logo appear when turning on box, no need for reset. WIFI/BT now working on CE nightly builds
still shitty as hell, got 10$ refund from mecool because of wifi. is it hardware issue or ?Last edited by shuky; 30 August 2019, 20:34.
My box is stock android 9 and has never flashed via custom rom maybe that is reason.
soooooo I have updated to android 9 and was able to boot from SD card to latest available stable Coreelec release for this box, but I am unable to turn it off now, from android it is possible, but if turning off from Coreelec it will just reboot. Is someone else facing this also or it is only my problem ?
There are currently 4172 users online. 0 members and 4172 guests.
