MECOOL KM8 Google Certified Android TV Box with Voice Remote - S905X Android 8.0 2/16GB VP9 HDR10 Dolby Audio YT 4K
Originally posted by tagi123 View Postmaybe 100 times....I am getting different error than the one in the guide.
Something like this: ROMCODE/initialize DDR/initialize status /USB control setup error
just try it and let me know, pls
Finally!, my Mecool KM8 device is back, I immediately checked if there was any firmware update but Videostrong halted it because of what happened to me and tagi123, by the way, tagi123 you should try with a different USB port, that's what I did, I hope you can recover your device because it worked for me.
Originally posted by tagi123 View PostHello,
happy to hear that
I was able to flash the box also.
Looks like the error that I got was related to lack of the power, because once the power cord was inserted, flash was successful.
With Corelelec on sd card it works great
Originally posted by tagi123 View Postno update for me also and it is also possible that there will be no future updateLast edited by delacosta78; 08 March 2019, 18:17.
Any news or rumors about an update? I'm desperate for an update, the WiFi doesn't work on my device, the remote control drops the bluetooth connection every time I put it into sleep mode and I can't connect any usb drives or hard drives because it doesn't recognize them , it's so annoying the way it works with the current firmware.Last edited by delacosta78; 21 March 2019, 00:16.
@delacosta78 I am not facing any of the problems you described.
On other side, most of the time my box is running on CoreElec, booting form SD. It is not completely bug free, but it is working much much more better than shitty, undone android firmware from Videostrong.
BTW does the voice control works for you ? In android offcourse.
Originally posted by tagi123 View Post@delacosta78 I am not facing any of the problems you described.
I discovered today the reason why the WiFi wasn't working on my device, turns out the bluetooth was responsible for this issue, they seem to be in conflict so I removed the remote control from the list of paired devices and the WiFi is working stable now, I still can use the remote control with infrared but I won't be able to use the mic for the assistant until they release a new firmware to fix this inconvenience.
Originally posted by delacosta78 View PostI discovered today the reason why the WiFi wasn't working on my device, turns out the bluetooth was responsible for this issue, they seem to be in conflict so I removed the remote control from the list of paired devices and the WiFi is working stable now, I still can use the remote control with infrared but I won't be able to use the mic for the assistant until they release a new firmware to fix this inconvenience.
It interferes with Bluetooth and vice-versa.
Not confident that a system update could do much about it.
Originally posted by The Brain View PostThis is an inconvenience of having only 2.4 GHz Wi-Fi, and not also 5 GHz.
There is a new KM8 at Gearbest with Android 9 Pie, I wonder if it's possible to extract the firmware and burn it to the current KM8 devices with Oreo, I guess someone has to get the device first, right?
https://www.gearbest.com/tv-box/pp_0...ml?wid=1433363
There are currently 1925 users online. 0 members and 1925 guests.
