MECOOL KM8 Google Certified Android TV Box with Voice Remote - S905X Android 8.0 2/16GB VP9 HDR10 Dolby Audio YT 4K
    Originally posted by bsbfoto24 View Post
    This version of Netflix TA picking up Full HD netflix_ 3.2.2 Android TV Mod
      Great find. This Netflix version, is the official Android TV OS app that works with a remote, and no mouse or other pointing device needed. It plays in 1080P but not 4k, which this box is capable of. Also, it does not support DD+ surround sound. But for this device, it works very well, I will use it.
      Thanks.
        I tried that also, reset using the Android Recovery, did not help. I have no idea why the firmware would be different before and after a reset, does not make sense.
        I tried today with flashing the OTA-USB update, same version as factory version that the box came with, but same result -> no CPU temp sensor...
          It baffles me, how the CPUtemp app installed and worked when I first received the box, but not after a reset.. Thanks for testing the OTA-USB update, now I don't have to.
            Don't do it if you don't have to. After such update I lost the option to select my language in Lean Keyboard, so I have to use only English because default keyboard also does not support it.
            Btw, CPU-Z also does not see any CPU temp sensor.
            One further question, are you able to use "Built in Chromecast". I am not able to get it to work.
            I'm not sending the box back since I upgraded passive cooling, but will probably install CoreElec-Kodi to internal and get rid of this crap OS forever
              If you are talking about "Chromecasting" from my phone, then, no. My LG phone does NOT support Chromecastilng natively....... But, I CAN cast almost everything from my computer.
                Thanks for this APK.
                It really works for 1080p playback with leanback interface.
                Yes, I am.
                Tested using my Android 7.0 LG phone.
                Except for Netflix, as expected, and for Facebook, which apparently is broken in every Chromecast device.
                  Yes, I am.
                  Tnx, tried with another phone and tablet and got it working OK.
                    Has anyone tried the atvXperience universal rom for S905X with this box?
                    having Widevine L1 (and PlayReady) with atvXperience , netflix should work
                      Sorry, for a few more days atvXperience S905X will still be named Universal s905x android tv v2.7:
                      has anyone tried it?
                      can somebody with this box try it?
                      Thanks in advance
                        atvXperience rom for s905X boxes has been released, its v2E to be on par with other chipsets like s912
                        you can grab it here:
                        if somebody who owns this box can try it and check if netflix and amazon prime video are working with this rom
                        supposedly netflix works with this roms on boxes that already have widevine L1 like the km8
                        Thanks in advance
                        Regards
                          Thanks in advance
                          Regards
                          Once we try it, how do we go back to the stock firmware??
                            My mistake, I though there was already a stock firmware out there, please nobody try anything until there is a backup firmware.
                            Maybe trebor can work its magic with mecool or gearbest a get a link to a stock firmware for this box
                            ​​​​​​​Best regards
                              If it delets Recovery, very difficult
                              That's why I don't do such experiments before I have a working TWRP recovery on my SD card. Since there is no TWRP recovery for this box, I'll pass...
