Regards
MECOOL KM8 Google Certified Android TV Box with Voice Remote - S905X Android 8.0 2/16GB VP9 HDR10 Dolby Audio YT 4K
Originally posted by Sholander View PostDoes anybody know if there is a TWRP SD Recovery image for this box. All TWRP images that I have in my colection don't work...MK818B, T428, ATV 1220, CS918S, TV01, S89H, R89, ADT-1, MK808B Plus, MINIX X8-H Plus, Tronsmart Orion R68
Originally posted by harckan View Post
Same here Kodi leia running Netflix addon, no play the video, my box Mecool M8S PRO Plus with Rom Magendanz, otherwise in CoreELEC run Fine 720p.
RegardsMK818B, T428, ATV 1220, CS918S, TV01, S89H, R89, ADT-1, MK808B Plus, MINIX X8-H Plus, Tronsmart Orion R68
Originally posted by wrxtasy View Post
That is not a bug but simply tablet Apps Not being coded for the Android TV OS leanback framework. All Android TV OS devices have the same issue with tablet Apps.
Kodi has to have the Chrome Launcher installed for Netflix to work. It installs using CoreELEC leia install..........
On my RK3328 device the Chrome Launcher addon says Chrome not found even if it's installed, not tried yet on KM8.
Is there a way to set it up that you know?
You only install the Chrome Launcher in Kodi 18 on Android and the Netflix addon?
Is there a way to set it up that you know?MK818B, T428, ATV 1220, CS918S, TV01, S89H, R89, ADT-1, MK808B Plus, MINIX X8-H Plus, Tronsmart Orion R68
Same thing on the KM8, can't get it to install to use with Netflix. Chrome is installed on Android, but Kodi can't connect it to the Netflix port. I even tried several different repositories to get Chrome Launcher to install, but not luck. Spent several hours, but finally gave up. I think I went through this before, but no luck. It only works under Leia running on LibreELEC or CoreELEC.
I was thinking of using the Chrome Launcher to add several video streaming sites to Kodi to easily open them for streaming services whose apps don't work on certain devices but can still stream through Chrome browser if you set it to Desktop mode. But it seems this plan won't work now if the addon can't even detect Chrome on Android.MK818B, T428, ATV 1220, CS918S, TV01, S89H, R89, ADT-1, MK808B Plus, MINIX X8-H Plus, Tronsmart Orion R68
Originally posted by bertvdb View PostHi All.
So I got my KM8 from Gearbest last week and I could not run our local IPTV service due to the box not being Google certified. Videostrong sent me a fw update which fixed the issue.
Which email address did you use to contact Videostrong? A couple of days ago I sent them emails to "[email protected]" and to "[email protected]" with some questions, but did not receive any replys.
Originally posted by The Brain View Post
It annoys me that I cannot see my Library on Play Store app to install all my favorite apps. Have to sideload everything...
Originally posted by wrxtasy View PostIf you can boot into Android Recovery on the KM8 (try the Playstore install - AMLogic TV Tool Box) and flash the Magisk v16.zip to Root the device.
There are currently 2970 users online. 2 members and 2968 guests.
