MECOOL KM8 Google Certified Android TV Box with Voice Remote - S905X Android 8.0 2/16GB VP9 HDR10 Dolby Audio YT 4K
Originally posted by zelder View PostMK818B, T428, ATV 1220, CS918S, TV01, S89H, R89, ADT-1, MK808B Plus, MINIX X8-H Plus, Tronsmart Orion R68
Mo123, that is part of the issue, from what I have read, all it says is 4k passthrough. Does NOT say what DRM HDCP version it supports. I really don't want to have to purchase a new one, but one of my HDMI inputs died a few months ago. This AVR has 5 rear HDMI ports on the back, but only 2 of them are 4K inputs.
AVR-S700W
Originally posted by clarkss12 View PostMo123, that is part of the issue, from what I have read, all it says is 4k passthrough. Does NOT say what DRM HDCP version it supports. I really don't want to have to purchase a new one, but one of my HDMI inputs died a few months ago. This AVR has 5 rear HDMI ports on the back, but only 2 of them are 4K inputs.
AVR-S700W
HDCP 2.2 support X, under HDMI
It looks like a good device, Intel with their crazy HDCP non backwards compatible technology.
Unfortunately not supported, so only a new AVR will give 4K Netflix or connecting directly to the tv without passthrough.
So, I will continue to use my existing Denon AVR......
Thanks, MOMK818B, T428, ATV 1220, CS918S, TV01, S89H, R89, ADT-1, MK808B Plus, MINIX X8-H Plus, Tronsmart Orion R68
^ Yeah, the ac adapter is pretty feeble at 200Ma.
PS
If anyone wants to buy mine, PM me an offer.Last edited by panchovilla; 08 August 2018, 00:53.
Finally received my Mecool KM8 Android TV box, and did a review. It does support HDCP 2.2 while connected directly to my 4k TV, but not supported when connected through my Denon AVR. Also, it does NOT support HD audio, it will play Dolby Digital and DTS, but not HD audio.
When connected directly to my 4k TV, it will play the modified Netflix app in 1080p.
I just saw your review and I've 2 question for you. Autoframe rate is supported for kodi and other app? It's possible to install libreelec/coreelec on a sd card or bootloader is locked?
Did you try to switch the hdmi cable? If your receiver support HDCP 2.2 there is no reason why it doesn't work...
Thanks.
Hello clarkss12 good to see that you have received your box so soon, thanks for sharing your review
any chances you can test prime video app v4.7.9 or v4.7.17?
also saw on aida64 that the box seems to be working in 32bits, I thought that android oreo would bring 64bits
on another note, will you be modding this box to bring the temps down with a fan? I saw the temps where really high on 4k 60fps where the highest, maybe with a fan and heatsink it wont drop so many frames
Originally posted by AlleV8 View PostI just saw your review and I've 2 question for you. Autoframe rate is supported for kodi and other app? It's possible to install libreelec/coreelec on a sd card or bootloader is locked?
Thanks.MK818B, T428, ATV 1220, CS918S, TV01, S89H, R89, ADT-1, MK808B Plus, MINIX X8-H Plus, Tronsmart Orion R68
Originally posted by rubenjavier View PostHello clarkss12 good to see that you have received your box so soon, thanks for sharing your review
on another note, will you be modding this box to bring the temps down with a fan? I saw the temps where really high on 4k 60fps where the highest, maybe with a fan and heatsink it wont drop so many framesMK818B, T428, ATV 1220, CS918S, TV01, S89H, R89, ADT-1, MK808B Plus, MINIX X8-H Plus, Tronsmart Orion R68
Originally posted by rubenjavier View PostMaybe using a fan like some people are doing with Mecool M8S Pro L,
by the pictures this box seems pretty closed up and looks like it lacks airflow
with a fan the M8S Pro L went down from 90ºC to 45ºCMK818B, T428, ATV 1220, CS918S, TV01, S89H, R89, ADT-1, MK808B Plus, MINIX X8-H Plus, Tronsmart Orion R68
Yes, I was also surprised that it was using 32 instead of 64 bit system. Perhaps, if I get time later in the week, I will sign up for a temporary Prime membership. Gotta sort out some other issues on this box first.
There are currently 1861 users online. 0 members and 1861 guests.
