MECOOL KM8 Google Certified Android TV Box with Voice Remote - S905X Android 8.0 2/16GB VP9 HDR10 Dolby Audio YT 4K
Originally posted by panchovilla View PostMK818B, T428, ATV 1220, CS918S, TV01, S89H, R89, ADT-1, MK808B Plus, MINIX X8-H Plus, Tronsmart Orion R68
Trebor said Netflix is not working now, maybe a couple of more months until Mecool gets the blessing from Netflix. He said Amazon Prime plays, but did not say what resolution. But the main requirement is met, Google certified AND HDCP 2.2.
Canal Digital is a cable TV provider in Norway. They launched a tv box (DVB-S) 6 months ago or so. It has all DRM certifications needed, but Netflix isn't working. They have been saying since Christmas that they think they'll get a deal. Google cast works, but not the Netflix app, and not casting Netflix. It is a shame. I would be skeptical about this box if you need 4K Netflix. I don't care that much since my Samsung Tizen plays Netflix great, but to those who need it; think about it twice.
Originally posted by sweetnonso View PostThe pertinent question here is if Mecool the company can get their M8S Pro L to play netflix on HD, why can't they simply do what they did on this particular box?MK818B, T428, ATV 1220, CS918S, TV01, S89H, R89, ADT-1, MK808B Plus, MINIX X8-H Plus, Tronsmart Orion R68
Originally posted by mo123 View PostSome interesting things to check perhaps?
Build.prop dump, to check firmware info.
Code:130|KM8:/ $ cat /system/build.prop cat: /system/build.prop: Permission denied 1|KM8:/ $ cp /system/build.prop /sdcard/ cp: /sdcard//build.prop: Permission denied 1|KM8:/ $ cat /system/vendor/build.prop cat: /system/vendor/build.prop: Permission denied 1|KM8:/ $ ls -la /system total 92 drwxr-xr-x 14 root root 4096 1970-01-01 08:00 . drwxr-xr-x 21 root root 0 2017-01-01 07:00 .. drwxr-xr-x 40 root root 4096 2008-12-31 23:00 app drwxr-xr-x 3 root shell 8192 2008-12-31 23:00 bin -rw------- 1 root root 4673 2008-12-31 23:00 build.prop -rw-r--r-- 1 root root 10311 2008-12-31 23:00 compatibility_matrix.xml drwxr-xr-x 11 root root 4096 2008-12-31 23:00 etc drwxr-xr-x 2 root root 4096 2008-12-31 23:00 fake-libs drwxr-xr-x 2 root root 8192 2008-12-31 23:00 fonts drwxr-xr-x 4 root root 4096 2008-12-31 23:00 framework drwxr-xr-x 5 root root 12288 2008-12-31 23:00 lib drwx------ 2 root root 4096 1970-01-01 08:00 lost+found -rw-r--r-- 1 root root 2544 2008-12-31 23:00 manifest.xml drwxr-xr-x 3 root root 4096 2008-12-31 23:00 media drwxr-xr-x 46 root root 4096 2008-12-31 23:00 priv-app drwxr-xr-x 3 root root 4096 2008-12-31 23:00 tts drwxr-xr-x 8 root root 4096 2008-12-31 23:00 usr lrw-r--r-- 1 root root 7 2008-12-31 23:00 vendor -> /vendor KM8:/ $ ls -la /system/vendor/ ls: /system/vendor//build.prop: Permission denied ls: /system/vendor//default.prop: Permission denied total 48 drwxr-xr-x 11 root root 4096 1970-01-01 08:00 . drwxr-xr-x 21 root root 0 2017-01-01 07:00 .. drwxr-xr-x 11 root shell 4096 2008-12-31 23:00 app drwxr-xr-x 3 root shell 4096 2008-12-31 23:00 bin drwxr-xr-x 11 root shell 4096 2008-12-31 23:00 etc drwxr-xr-x 2 root shell 4096 2008-12-31 23:00 framework drwxr-xr-x 9 root shell 4096 2008-12-31 23:00 lib drwx------ 2 root root 4096 1970-01-01 08:00 lost+found -rw-r--r-- 1 root root 6607 2008-12-31 23:00 manifest.xml drwxr-xr-x 2 root shell 4096 2008-12-31 23:00 package_config drwxr-xr-x 3 root shell 4096 2008-12-31 23:00 usr drwxr-xr-x 2 root shell 4096 2008-12-31 23:00 xbin 1|KM8:/ $
Originally posted by Robbynaish View Post
The question is... really this new box actually is better than the Pro L?
I only purchased this device to if it indeed was Google certified and supported HDCP 2.2. Probably not a very good reason for most sane people.MK818B, T428, ATV 1220, CS918S, TV01, S89H, R89, ADT-1, MK808B Plus, MINIX X8-H Plus, Tronsmart Orion R68
That would be what your needs are. IF you NEED Chromecasting, then, yes it would be better than the "L". IF they can provide Netflix in 4k, then YES, it would be better than the "L". Otherwise probably NOT. There may be other benefits, but not sure what. Or for some, if it supports Amazon Prime streaming media.
What fun would that be??? I have given away all my devices that JUST work, too boring to use.
I just bought a refurbished one and lucked out. It actually works with vader and eternal. People warned me it won't work with IPTV.
I still have the H96 with a fan . But, it's just too noisy .
FTV2 has got to be the best box , dollar for dollar, ever made .
There are currently 3583 users online. 1 members and 3582 guests.
