MECOOL KM8 Google Certified Android TV Box with Voice Remote - S905X Android 8.0 2/16GB VP9 HDR10 Dolby Audio YT 4K
Originally posted by clarkss12 View PostThe lack of Netflix is the only thing missing for me.
Originally posted by Sholander
For best Youtube 2/4K experience on my S905W and S912 boxes I use "SmartYouTube TV"
Any other random video, including the Google Play Movies trailers, plays fine in 1080p, my TV's max resolution.
Are you sure the box of yours runs it above 480p?
Originally posted by The Brain View PostWhat Wrxtasy and I are referring to are the Google Play Movies titles, which can be played through the Google Play Movies app or the official YouTube app, but not using Smart YouTube TV or any other app.
Are you sure the box of yours runs it above 480p?MK818B, T428, ATV 1220, CS918S, TV01, S89H, R89, ADT-1, MK808B Plus, MINIX X8-H Plus, Tronsmart Orion R68
I played the movie "Elf" using the Google Play app, and it **looked** like it was HD, but no way to verify it. It does play with DD+ audio, so that is a good indication that it is being played in HD. BUTT, that same video playing from the Google Play app on one of my 2 year old Android boxes plays the same with DD+.
You must be logged in to the same Google Account as the Google Play Movies app.
Originally posted by The Brain View PostCould you please play that same movie through the YouTube app and see what the stats for nerds show as current and optimal resolution?
You must be logged in to the same Google Account as the Google Play Movies app.MK818B, T428, ATV 1220, CS918S, TV01, S89H, R89, ADT-1, MK808B Plus, MINIX X8-H Plus, Tronsmart Orion R68
I have no idea how to do that.
- Scroll down to Accounts
- Check if it's already logged in. If not, log in.
- Scroll up to Library
- Move to the right and scroll down to Purchases
- Move to the right again and pick a movie you know is available in HD through Google Play Movies service, preferably the same you tested earlier.
From now on I believe you already know, but I'll describe it anyway, so more people can check it, eventually:
- Once it's playing, select More Options and then Stats for nerds, the last icon, one with a bug shape.
- Now a set of information about the streaming is shown, including Current and Optimal Resolutions. This last one appears to be the maximum resolution the streaming can reach under the tech specs of the media set, without consider the connection speed, which in turn can affect the Current Resolution.
- You also can simply choose, instead of Stats for nerds, Quality, the one with a HD icon, and see if it shows any option above 480p.
OK. I have just made a new attempt and was able to play a video from my Google Play Movies library in HD.
It's the short film "Shaun the Sheep: The Big Chase"
And I have also come across a title for rent/sale whose description says it CAN be played in HD in this device:
After reading the Google Play Movies Help page about the HD movie & TV show availability, which states that HD playback is always available on Chromecast, Android TV, and Roku, and that if you're watching on a non-Chrome browser (let's extend this to any other non-certified device), the ability to play in HD will depend on studio licensing agreements and will vary across videos, we can assume that Mecool KM8 is not really a Google Certified Android TV device or at least not yet, in the case Videostrong has got the rights to do it but didn't give proper attention to the details.
[QUOTE=wrxtasy;n740851]If you can boot into Android Recovery on the KM8 (try the Playstore install - AMLogic TV Tool Box) and flash the Magisk v16.zip to Root the device.
Then the Android build.prop can be modded to "masquerade" as an already approved Netflix
Half of that went over my head...
But you sir Are the reason I come here
Thanks for lending us a hand... And the databank too.
... This goes for 'The Brain' Also!
Hi All.
So I got my KM8 from Gearbest last week and I could not run our local IPTV service due to the box not being Google certified. Videostrong sent me a fw update which fixed the issue. Netflix ATV app still not running but I got a regular android version running. Do not reckon the resolution is 1080p though as it is not the ATV app.
https://mega.nz/#F!NQxVURDB!__BT-yJmLOSFAuqsqsb-iA
Thanks, now we have a Zip backup for this device............MK818B, T428, ATV 1220, CS918S, TV01, S89H, R89, ADT-1, MK808B Plus, MINIX X8-H Plus, Tronsmart Orion R68
I ask because mine KM8, also from Gearbest, should arrive tomorrow, so I'm just gathering info and wander should I also need
"KM8-ota-V0412.201806271453" version. How did you install it? Just copied the zip file to USB and chose update from Android, or?
Hi guys,
I'm interested in buying this thing and I have a couple of questions:
1. Could someone check if the Dazn app work? Or at least if it's in the store and can be installed. It may depend on your country, according to wikipedia it's available in Austria, Germany, Japan, Switzerland, Canada, Italy, US
2. I'm going to need WiFi. Definitely. So, if the signal is so poor as you guys say, is there anything that can be done to improve it? Replacing the external antenna for instance, or even better, getting a USB dongle (I read some of them work with Android boxes, provided they have the right firmware).
That file is interesting. It is the same version that is currently installed on my KM8 box.
There are currently 3349 users online. 0 members and 3349 guests.
