MECOOL KM8 Google Certified Android TV Box with Voice Remote - S905X Android 8.0 2/16GB VP9 HDR10 Dolby Audio YT 4K
So I bricked my new km8 atv already. Os
blows. No root, kingroot won't root it either. No landscape view option in settings so half the apps I loaded are sideways. I tried burning a few different firmwares with same chipset like the m8s pro plus but I get loper identity error. However beelink mxiii does work on it except no wifi. Anyone have mecool bm8 firmware? I only have a twrp backup of it and can't root new km8 so no twrp. New km8 firmware zip would be nice to I could unpack and replace recovery with twrp. Either way new km8 sucks so good luck everyone. Hardware is great of course, just have a project now.
Originally posted by jillblow777 View Post
Where can I get that firmware, everything I find is km8 pro
I solved landscape mod of my "sideways" apps with "setorientation_1.1.4-10.apk"
Hey guys, just to let you know so trebor can open a new thread
There is a new official AndroidTV box with s905x and Netflix approved, its called Jetsream by Ematic
you can get it at walmart:
walmart link, maybe next week they will have stock:
It went through the fcc last month
The manual shows android 8.1, if this is true, maybe we get some fixes:
WiFi ac, optical audio, ethernet port and SDcard slot
Im in europe and cant buy one yet... maybe someone on the states can get one in the coming weeks from a brick and mortar shop
Originally posted by mo123 View PostHeard Netflix blacklisted Videostrong, so all their devices won't be able to use it anymore, not even with new burnkeytools in future.MK818B, T428, ATV 1220, CS918S, TV01, S89H, R89, ADT-1, MK808B Plus, MINIX X8-H Plus, Tronsmart Orion R68
I don't have a 4K visualization device so I can't test it, but it works at 1080p without problems once you set the correct ESN (tested on a Mecool M8S Pro+ and a Mecool KI Pro)
Originally posted by A600 View Post
You can use the Kodi addon and even get 4K + HDR: https://github.com/asciidisco/plugin.video.netflix with the latest nightly Kodi Leia build.
I don't have a 4K visualization device so I can't test it, but it works at 1080p without problems once you set the correct ESN (tested on a Mecool M8S Pro+ and a Mecool KI Pro)MK818B, T428, ATV 1220, CS918S, TV01, S89H, R89, ADT-1, MK808B Plus, MINIX X8-H Plus, Tronsmart Orion R68
I tried on my Nexbox A95X Pro (Amlogic S905W), it would start to play then quit.
NFANDROID2-BLABLABLA-XXXX-XXXXXXXXXXXXXXXXXXXXXX where XXXX-XXXXXXXXX is a bunch of numbers. The ESN you need for the addon is NFANDROID2-BLABLABLA.
For the Mecool KI Pro, for example is:
NFANDROID2-PRV-NEXUSPLAYERFUGU-VS===KI=PRO
Is there a fix for NTFS file system on Oreo 8.0 for this box?
Is there a working TWRP recovery for SD card for this box?
No
Three weeks ago Mecool replied to me: "About the KM8 Android TV, there is no update. It needs time".
My emails from last week and this week remain unanswered, I even sent them patches to fix all the problems.
Seems no one is interested to fix it, so I gave up.
All the S905X AndroidTV Oreo devices are broken, some a lot more than others.
There are currently 4712 users online. 0 members and 4712 guests.
