MECOOL KM8 Google Certified Android TV Box with Voice Remote - S905X Android 8.0 2/16GB VP9 HDR10 Dolby Audio YT 4K
Magisk releases new version v18.0. I have also flashed new patched boot.img and still getting bootloop. I am starting doubt if we can get any benefits even we do have a working build for twrp.Last edited by lukedoomer; 10 December 2018, 04:18.
Originally posted by sweetnonso View Post
Can you point me towards that modded version please?
It gives tvq-pb-103(2.10.0) error.
Anyway, here goes the link for the bsbfoto24 post: https://forum.freaktab.com/forum/tv-...707#post743707
And the direct link for the modded apk:
Yes, but for Android only.
Netfix 720p works OK on CoreElec Kodi_Leia_final version. Just enough reason to save the box from recycling
Btw, did anybody succeed to root this box with MagiskManager? Did anybody find any version of TWRP that works on this box?
Android 8.0 on this box is pretty useless...Last edited by Sholander; 07 February 2019, 13:30.
I'm new to this forum, I had to create an account because something weird happened to me today with my Mecool KM8 device:
I noticed there was a new firmware update, I decided to install it, but when the update was in progress I noticed the word "test" between the name of the update and I didn't want to cancel it to avoid bricking my device, the problem is, it was bricked, somehow that was a testing firmware and I supposed it wasn't meant to be installed by users, the firmware seems to be Android Pie because it had the 9.0 numbering, anyway, can you or anybody tell me how can I install the original firmware that was in my device?
By the way, if everyone of you go to settings and check for any update and you see this update I'm talking about, DON'T INSTALL IT!, it will brick your devices like it did with mine.
Thank you in advance, I really want my device back as it was before.
I'm going to let someone else handle this that has more km8 experience help you.
But, many ROMs both OEM and Custom have the phrase "test keys" in the file name. Post a link to the actual ROM that you loaded. In the meantime I guess you have entered recovery and attempted a factory wipe? And all this box has is a stock recovery program? You have no TWRP, or other alternative 3rd party recovery?
In any case, NEVER wipe the system partition.
Good luck !Kris....don't forget my boxes! Okay?
Originally posted by ClarkKent View PostI'm going to let someone else handle this that has more km8 experience help you.
Good luck !
Re-download the file, if in fact it is meant for your specific box, sometimes they can be corrupt.
Load into 1st level hierarchy of both a sd card AND a usb thumb drive.
Put both in the box, with power cord out. Then depress the reset button while plugging in the power cord... Hold reset button depressed for approx 10 seconds. You should enter recover at this time
Select the file on either of the memory devices and let it run..
Doesn't work? Use the other one you've loadedKris....don't forget my boxes! Okay?
There are currently 2915 users online. 1 members and 2914 guests.
