Regards
MECOOL KM8 Google Certified Android TV Box with Voice Remote - S905X Android 8.0 2/16GB VP9 HDR10 Dolby Audio YT 4K
Originally posted by Sholander View PostYou cannot add any drivers for WiFi on Android by yourself (at least not easybecause they need to be supported by kernel.
If you have any external USB WiFi dongle, connect it and see if it's recognized by Android. If it is - OK, and if it's not then there is nothing you can do about it...
Originally posted by Sholander View PostOn my KM8 on Android 8.0 USB-WiFi dongles with Realtek RT5370 chipset work OK.
Edup AC1619 600 Mbps WiFi dongle with Realtek RTL8811AU chipset does not work and is not recognized in Android 8.0
Both dongles work on this box with CoreElec 9.2 with Kodi 18.4 installed on uSD card...
Originally posted by MikeG2001 View Posthey just wondering if there's any Netflix compatibility with this 9.0 update? anyone get Netflix working? which how? netflix ATV5.4 maybe? I flashed that minixfreak rom no wifi or BT tho hope I can get the 9.0 update with Netflix working??
Been using this for quite some now with the latest official 9.0 firmware. Only problem is that when it has been on wifi for a while it does not drop it, but it doesn't just work. Cycling power helps again for a while. It seems that if I watch a long movie without pausing it, RW/FF etc wifi stays ok for full movie. Second selection would most like need cycling power.
Anyone else on the same boat? Any resolutions to this?Last edited by MiXAL; 31 December 2019, 12:29.
There are currently 2684 users online. 1 members and 2683 guests.
