MECOOL KM8 Google Certified Android TV Box with Voice Remote - S905X Android 8.0 2/16GB VP9 HDR10 Dolby Audio YT 4K
Originally posted by Sholander View PostMK818B, T428, ATV 1220, CS918S, TV01, S89H, R89, ADT-1, MK808B Plus, MINIX X8-H Plus, Tronsmart Orion R68
Originally posted by SholanderI see these KM8 boxes on the list in BurnKeyTools v1.06:
KM8_KB5
KM8_KB5_4335
KM8_KM8
KM8_KM8_6212
KM8_ZITO
M8S_PRO_W_W5
Are these pre-Oreo versions, or one has to have exact KM8_Box version for app to install ?
Originally posted by The Brain View PostIt must refer to the others KM8 boxes, which are not Android TV.
http://www.videostrong.com/app/list....lt=25&PageNo=2MK818B, T428, ATV 1220, CS918S, TV01, S89H, R89, ADT-1, MK808B Plus, MINIX X8-H Plus, Tronsmart Orion R68
Originally posted by wrxtasy View PostWhy do you need to reflash WideVine L1 DRM ?
Has it not already bee verified with DRM Info App that this device has L1 DRM.
All that I suspect is needed is the correct (fake) Netflix entry in the build.prop
And for that the device needs to be rooted, or Guest needs to work some magic !MK818B, T428, ATV 1220, CS918S, TV01, S89H, R89, ADT-1, MK808B Plus, MINIX X8-H Plus, Tronsmart Orion R68
Guest
Just a quick update on TWRP development for this box...
I'm able to build TWRP 3.2.3-0 using the prebuilt kernel from this OEM firmware release. I was initially getting no video, but downgrading to an older systemcontrol_static fixed that problem. (This has also been required on other TWRP builds for Amlogic S905X.) It boots to TWRP Recovery, looks great, and seems to fully function...for about 30 seconds. After that, it goes into a bootloop and just repeatedly flashes the logo screen. Even if you cycle power after that, it still goes into that bootloop.
So, at this point I've got to look for clues in the logcat, but with everything else going on right now I just haven't had the time.
Originally posted by Magendanz View PostJust a quick update on TWRP development for this box...
So, at this point I've got to look for clues in the logcat, but with everything else going on right now I just haven't had the time.MK818B, T428, ATV 1220, CS918S, TV01, S89H, R89, ADT-1, MK808B Plus, MINIX X8-H Plus, Tronsmart Orion R68
Thank you. Tried to install it, but it won't install.
Don't know where else to ask you, so I'll do it here:
Watching your pretty long Yotube video I see that you are using an app to show CPU temperature floating on top of the screen. Tried several apps, but can't get them to work properly.
Which app do you use for temp display?
Asking, because I "upgraded" my passive cooling replacing ridiculously small CPU heat-sink with a proper one, so I'd like to check temperatures when running Android.
On CoreElec my idle temp now is 48°C compared to 65°C with original heat-sink :
Same result here...
On CoreElec my idle temp now is 48°C compared to 65°C with original heat-sink :MK818B, T428, ATV 1220, CS918S, TV01, S89H, R89, ADT-1, MK808B Plus, MINIX X8-H Plus, Tronsmart Orion R68
WTF, I also did a factory reset, and since then I do not see CPU temp in Aida64, infact Aida does not see the sensor for CPU temp, but one for Battery temp, which I'm sure does not exist. I'm sure that before Factory reset, Aida reported correct CPU temp from that sensor. This is one heavily *uckedup box...
At least, I'm sure that the sensor exists and works, because CoreElec reports correct cpu temp.
Maybe I should try factory reset via Android Recovery.., if that can give different result.
Originally posted by Sholander View PostWTF, I also did a factory reset, and since then I do not see CPU temp in Aida64, infact Aida does not see the sensor for CPU temp, but one for Battery temp, which I'm sure does not exist. I'm sure that before Factory reset, Aida reported correct CPU temp from that sensor. This is one heavily *uckedup box...
Maybe I should try factory reset via Android Recovery.., if that can give different result.MK818B, T428, ATV 1220, CS918S, TV01, S89H, R89, ADT-1, MK808B Plus, MINIX X8-H Plus, Tronsmart Orion R68
There are currently 1703 users online. 0 members and 1703 guests.
