Amlogic Next7P12-8G Modified Recovery - Stock Rom & Flashable Root
    Originally posted by BlackKnight330 View Post
    You need the Modified Stock 3e Recovery unzip it to your external sd card, then put the zipped Root Package to the external sd.
    Thx man the "Modified Stock 3e Recovery" is working fine
    but I still have a problem this rom doesn't work with my tablet
      What tablet do you have and what ROM is currently on your tablet?
      Freaktab Rom Developer
        next7p12 4g
        I installed next8p12 rom with ur "Modified Stock 3e Recovery"
        and its worked but the rom is bigger than my screen
          next7p12 4g
          I don't think there are any ROMs available for the Next7P12-4G... not even a stock one...
          I don't think I can make one unless someone else who has that model can root it and dump the stock ROM from the device.
          What was the problem when you tried the Next7P12-8G ROM? Did it fail to install or install but not boot properly?
          ShaunMT
            ShaunMT
            Its fail to install
              next7p12 4g
              Where did you buy this? I can't even find a Next7P12-4G???
              I'm guessing this is an Amlogic based Next7 with only 4GB internal storage? Did it come with Google Apps?
              ShaunMT
                This rom is worked
                but its bigger than my screen
                  ShaunMT
                  yes its come with Google Apps
                  this is it http://amzn.com/B007N9F9UC
                  amlogic next7p12
                    Its fail to install
                    Does it display an error message when it fails? At what step does it fail and what if anything does it say on screen about the failure?
                    I wonder if it is just too large for your model?
                    ShaunMT
                      amlogic next7p12
                      I found some info about your model on the Nextbook site... they did make two different versions, 1 with 4 GB internal storage and one with 8GB internal storage. Never seen a 4GB model. Trying to learn if there were any other differences.
                      ShaunMT
                        ShaunMT
                        When I open "Recovery Mode"
                        I see that message:
                        E:Bad bootloader arguments
                        "(null)"
                        E:unknown volume for path [/udisk/factory_upgrade_param.aml]
                        E:Can't mount /udisk/factory-update-param.aml
                        And When I try to update the rom Its saying:
                        -- install /sdcard ...
                        Then its stop without error message
                          Originally posted by rumpunchpow View Post
                          If you were in the room I'd kiss you square on the lips and not care who saw it! LOL Thank you for saving my sanity and my 7P12. Everything worked as expected and my tablet is now no longer in zombie land.
                          Question...
                          Is your tablet the 8 GB internal storage model (possibly labeled Next7P12-8G or Next7SE-8G) or is it the 4 GB internal memory model (possibly labeled Next712-4G, Next7SE-4G or NEXT7P12GP)?
                            I see that message:
                            "(null)"
                            The messages about the factory_upgrade_param.aml are normal. That file is an optional script that can be used to install an update and reboot the tablet with no user interaction. It never even shows the user the recovery if it finds such a script it just runs the script whether the user likes it or not.
                            I am very surprised that you don't get any message at all after --install /sdcard---
                            What happens next? Does it just reboot or do you have to turn it off manually?
                            ShaunMT
                              ShaunMT
                              I have to turn it off manually
                                So it never even starts the signature verification? Are you sure you waited long enough?
                                With my Next8P12 and Next8HD8G ROMS, I have noticed there is quite a delay between when ---install SD Card--- appears and when the signature verification begins. I don't know why, but these steps are handled by the recovery and I can't do anything to reduce the delay.
                                ShaunMT
