Amlogic Next7P12-8G Modified Recovery - Stock Rom & Flashable Root
    Originally posted by shaunmt View Post
    So it never even starts the signature verification? Are you sure you waited long enough?
    With my Next8P12 and Next8HD8G ROMS, I have noticed there is quite a delay between when ---install SD Card--- appears and when the signature verification begins. I don't know why, but these steps are handled by the recovery and I can't do anything to reduce the delay.
    ShaunMT
    Yes I have watied until --install SD Card... disappeared
    Its never begin signature verification
      I have never seen any ROM or any type of update.zip package freeze a tablet or otherwise fail to install before the signature verification completed.
      I wonder if there is something wrong with your ROM download. Have you tried redownloading the ROM?
      After rereading some of rumpunchpow's posts, I believe he successfully installed this ROM on a Next7P12-4G / Next7P12GP.
      ShaunMT
      Freaktab Rom Developer
        ShaunMT
        May be because I cant wipe media partition?
        I see that error message: "E:format_volume: fdisk.media failed on /dev/block/avnft18p1 (127)"
        Is that make difference?
          I believe /media is the mount point for the external SD card. You can't wipe it while it is in use. For example, if you booted from a file on it...
          None of my ROM files attempt to do anything with /media, unless you count reading files from the external SD Card.
          ShaunMT
            yes its come with Google Apps
            this is it http://amzn.com/B007N9F9UC
            amlogic next7p12
            Are you sure your tablet is an Amlogic model?
            There should be a model no: and fcc id: printed on the back, what do they say?
            ShaunMT
              THANK YOU!!
              Worked for me too!!!
              very happy banana
              back to stock rom, now running updates, thank you so much.
                very happy banana
                Glad to hear it!
                Can you confirm your model?
                ShaunMT
                  ShaunMT
                  That's the Model No: NEXT7P12
                  FCC Id:S7JNEXT7P12
                  The Serial is: YF1212
                    FCC Id:S7JNEXT7P12
                    and what about the IC code: or IC ID: ?
                      How Can I find IC Code?
                        It should IC Code or IC ID should also be printed on the back of the tablet.
                          May be u mean this: POM727MC
                          I couldnt find "IC" or "IC ID"
                            I believe this ROM should work on your model. Have you tried downloading the stock ROM for the Next7P12-8G again, I think maybe your download was corrupted.
                            ShaunMT
                              ShaunMT
                              Ok I'm downloading it again
                                The modified recovery worked right? You downloaded the recovery, unzipped it, placed the uImage_recovery file on the top level of your external SD card and booted by holding power and volume, correct?
                                When the ROM download finishes, do NOT open or unzip the ROM. Just put it on your external SD card, reboot to recovery and attempt to flash it.
                                ShaunMT
