Amlogic Next7P12-8G Modified Recovery - Stock Rom & Flashable Root
    Originally posted by jac1599 View Post
    Well, the reflash worked. Battery level is now functional. Thanks again! Can't wait to see some custom ROMS!
    Glad it worked out for you!
    The custom ROMs are coming, I just wish I had more time to spend on them lately.
    ShaunMT
    Freaktab Rom Developer
      Good morning to everyone following this thread.
      I was wondering if anyone with a 4gb model tried this stock rom and could confirm whether it works or not?
      I have a working rooted next7p12-g 4gb.
      Why do I want to know if the stock rom works if my tablet is currently working? Because I am very much interested in possible future custom roms, and this way we could start to identify compatible devices. If I find a way to nandroid, I will surely test and give feedback myself. In the mean time, I would surely appreciate feedback from other 4gb owners.
        If you're already rooted, you could just do a system dump (Use dd to dump all the partitions, not romdump or onandroid), and upload them for me to work on. I haven't had an opportunity to compare the ROMs for the two models.
        ShaunMT
          ShaunMT
          Sorry, I am very unfamiliar with dumps.
          Did a bit of googling, but it seems the process of identifying the partition name differ.
          If I do:
          Code:
          cat /proc/partitions
          I get:
          Code:
          major minor  #blocks  name
             7        3       7308 loop3
             7        5      52007 loop5
             7        6      24980 loop6
            31        0      16384 mtdblock0
            31        1       8192 mtdblock1
            31        2       8192 mtdblock2
            31        3       8192 mtdblock3
            31        4       8192 mtdblock4
            31        5     524288 mtdblock5
            31        6     131072 mtdblock6
            31        7     524288 mtdblock7
            31        8    2957312 mtdblock8
           250       32    2592768 avnftl8
           250       33    2586433 avnftl8p1
           253        0   31166976 cardblksd
           253        1   31162880 cardblksd1
           254        2       7308 dm-2
           254        4      52006 dm-4
             7        8      49928 loop8
           254        7      49927 dm-7
             7        9       9387 loop9
           254        8       9387 dm-8
           254        5      24979 dm-5
          So it seems my next steps should be:
          Code:
          [COLOR=#222225]su
          [/COLOR][COLOR=#222225]dd if=[/COLOR][B][COLOR=Blue]/yourMountingPoint[/COLOR][/B][COLOR=#222225] of=[/COLOR][B][COLOR=Green]/yourDestination[/COLOR][COLOR=Red]/partitionType[/COLOR][/B]
          But I am not sure what to use as /yourMountingPoint and /partitionType.
            If I do:
            Code:
            I get:
            Code:
               7        3       7308 loop3
               7        5      52007 loop5
               7        6      24980 loop6
              31        1       8192 mtdblock1
              31        2       8192 mtdblock2
              31        3       8192 mtdblock3
              31        4       8192 mtdblock4
             254        2       7308 dm-2
             254        4      52006 dm-4
               7        8      49928 loop8
             254        7      49927 dm-7
               7        9       9387 loop9
             254        8       9387 dm-8
             254        5      24979 dm-5
            Code:
            [COLOR=#222225]su
            Do
            Code:
            cat proc/mtd
            You should get output something like this:
            Code:
            dev:     size     erasesize     name
            mtd0: 00800000 00200000 "bootloader"
            mtd1: 00800000 00200000 "logo"
            mtd2: 00800000 00200000 "aml_logo"
            mtd3: 00800000 00200000 "recovery"
            mtd4: 00800000 00200000 "boot"
            mtd5: 20000000 00200000 "system"
            mtd6: 00800000 00200000 "cache"
            mtd7: 40000000 00200000 "userdata"
            mtd8: 18c00000 00200000 "NFTL_Part"
            You need bootloader, logo, aml_logo, recovery, boot, and system for a full ROM.
            Cache is user settings. Userdata is downloaded apps. These are usually wiped and not restored with a ROM. Could be useful for backups though.
            Don't mess with NFTL_Part!
            Output file names should be as follows:
            "bootloader" = bootloader.img
            "logo" = logo.img
            "aml_logo" = aml_logo.img
            "recovery" = recovery.img
            "boot" = boot.img
            "system" = system
            "userdata" =userdata
            So your command lines for dumping should be in this format:
            dd if=/dev/mtd/mtd# of=/sdcard/external_sdcard/ouputfilename
            Check your mtd#'s on your device using cat proc/mtd and fill in the mtd#'s and output file #'s and enter the dd commands one line at a time.
            If your cat proc/mtd output matches my device, then your lines would be:
            Code:
            dd if=/dev/mtd/mtd0 of=/sdcard/external_sdcard/bootloader.img
            dd if=/dev/mtd/mtd1 of=/sdcard/external_sdcard/logo.img
            dd if=/dev/mtd/mtd2 of=/sdcard/external_sdcard/aml_logo.img
            dd if=/dev/mtd/mtd3 of=/sdcard/external_sdcard/recovery.img
            dd if=/dev/mtd/mtd4 of=/sdcard/external_sdcard/boot.img
            dd if=/dev/mtd/mtd5 of=/sdcard/external_sdcard/system[COLOR=Red]
            [/COLOR]
            When done, copy the files and folders you dumped off your external sd card, zip them all up together in a single zip file, upload them and let me know where I can download them.
            ShaunMT
              Do
              Code:
              cat proc/mtd
              Code:
              "logo" = logo.img
              "boot" = boot.img
              "system" = system
              Code:
              [/COLOR]
              ShaunMT
              great, I got all 6. By the way, yes, my output from cat proc/mtd matches yours, except for the two size columns.
              Will upload soon and notify you via PM of the location.
              Just one more noob question. Can you confirm that none of my private info and account info will be in those six dumps? I would guess it would be in userdata, but I just need 100% confirmation please.
                Re: Amlogic Next7P12-8G Modified Recovery - Stock Rom & Flashable Root
                Any personal data would be in cache or user data.
                Sent from my SPH-L710 using Tapatalk 4
                  Hello
                  My next7p12 4g
                  Serial YF0413...
                  won't boot in recovery-mode. What should i do?
                    Originally posted by Balmung83 View Post
                    Hello
                    My next7p12 4g
                    Serial YF0413...
                    Does your tablet boot normally into Android? Are you running the original ROM or a ROM that you flashed? If you flashed a ROM, what ROM are you using? Are trying to boot to stock recovery or a modified recovery? If a modified recovery, which one? Are you booting recovery from internal flash or external SD card?
                    And... perhaps most important... what were you attempting to do before this condition occurred?
                    ShaunMT
                      ShaunMT
                      It does boot normally.
                      I'm running the original ROM.
                      External, internal
                      I've tried to root my device with the Impactor-method on windows before, but the Next7P12 was not recognised by Minimal ADB/Fastboot and Impactor.
                        External, internal
                        I don't know how the Cydia Impactor tool works, but it sounds like it may have damaged your recovery partition. Not to worry though, these tablets can also boot recovery from an external SD card. Do you have an external SD Card?
                        I only recently received a copy of the ROM for your model. I'll try to post a modified recovery that you can place on your SD card and a stock ROM that you can flash to fix your internal recovery by this weekend.
                        ShaunMT
                          ... Do you have an external SD Card?
                          Yes: 1GB, 2, 4 and 8GB.
                          Thank you very much. Your efforts are very much appreciated.
                            Android version
                            I'm really glad I found this thread. Just a question, for what the Android version is this? I'm using Android 4.1.1, my serial is yf1212 series and my item # is next7d12r. Will this rom work for me? BTW, mine is manufactured Dec 2012
                            thanks,
                            christian
                            Last edited by christian404; 10 October 2013, 06:19. Reason: typo because of auto correct of tablet
                              thanks,
                              christian
                              This is also android 4.1.1, and it is probably not compatible with your model. It is just a plain stock ROM anyway, no new features.
                              ShaunMT
                                ShaunMT
                                How about the flashable root will it work in my model?
                                thanks for the fast reply.
